Here is your tip of the day for U carborated Jeepers.
1. Check the idle settings.
2. Check the choke settings.
3. Check the vacuum lines/plugs.
4. Check the fuel lines, replace if worn/collapsing.
5. Check the top holding screws.
6. Check the mounting NUTS.
P.S. Mine mounting nuts/top holding screws were finger tight
Carb Tech Tip for better gas mileage
Posted 16 December 2007 - 03:35 PM
