Rear D44 Axle Shaft Bearing How do I take it off and put it back on
Posted 09 December 2007 - 03:39 PM
-Matt
00' TJ
86' BLONDE
Posted 09 December 2007 - 04:03 PM
Posted 09 December 2007 - 04:07 PM
00' TJ
86' BLONDE
Posted 09 December 2007 - 05:03 PM
myspace- http://www.myspace.com/baconspage
mymudspace- http://www.mymudspac...ame_bad_monday/
myjeepspace- htpp://www.myjeepspace.com/xjoutkast
Posted 09 December 2007 - 05:44 PM
Posted 10 December 2007 - 12:02 AM
You are welcome to come and get it for a steal-if you know what I mean.
Practice on it, save the good parts and junk the rest.
Posted 10 December 2007 - 04:59 AM
oreo, on Dec 9 2007, 03:39 PM, said:
-Matt
Getting it off is not the problem, if necessary you can use a grinder and cut one side of it and knock it off. However, IMHO you are gonna need a press to put the new one on. Another bit of advice, load the bearing up with a good quality axle grease before reinstalling the shaft. Reason is, by the time your gear oil works its way down to the NEW bearing you may burn it out. I suggest you merely take your axle down to your friendly mechanic's shop and I am sure they will press one on and/or off for a minor amount of money, like maybe a $5 tip. Only takes a minute or two per bearing. john
Posted 10 December 2007 - 05:57 AM
Posted 12 December 2007 - 09:16 PM
http://www.sears.com/shc/s/p_10153_12605_0...keyword=bearing
http://www.northerntool.com/webapp/wcs/sto...23924_200023924
Press
http://www.northerntool.com/webapp/wcs/sto...26415_200326415
Posted 22 December 2007 - 01:21 AM
John, on Dec 10 2007, 04:59 AM, said:
Taking it to a shop for a $5 tip. I must not know the shops you know. I have been charged $60 to press the bearing on, when I go de mine again I"m going to by a press at Northen or Pep Boys.
Posted 22 December 2007 - 05:27 AM
This is perhaps close to my last post. On 12/27 the movers come to take my stuff to New Mexico, I will have to find MY friendly mechanic all over again in a new town (Las Cruces) hope I have luck. john
