Plasma Cutters and Air Tools
Posted 29 November 2007 - 09:41 PM
Pics/costs/write-up:
http://www.savagesun..._tools_on_.html
Scottsdale, AZ
e mail: click here!
www.savagesun4x4.com
Posted 29 November 2007 - 09:43 PM
Gus
Posted 29 November 2007 - 09:44 PM
Posted 29 November 2007 - 09:55 PM
73_cj_project, on Nov 29 2007, 07:43 PM, said:
Gus
Wife bought it for me for Christmas and I got a REALLY great deal on it!!!!
Rollbar, on Nov 29 2007, 07:44 PM, said:
Yes, did you read the part about the two air hoses, one is yellow for air tools and one is red for my plasma cutter. The oiler is attached to the hose itself at the point where it attaches to the air tool which keeps my hose from getting gummed up.
Scottsdale, AZ
e mail: click here!
Posted 29 November 2007 - 09:58 PM
SavageSun, on Nov 29 2007, 09:55 PM, said:
Sorry , missed that part. Been working on the PC since 4PM. Time to take a break
Posted 30 November 2007 - 07:41 AM
I used to install and repair air compressors.
Be sure to drain the air tank often, I've seen the results of a tank that blew up, not a pretty site.
How's the water issue on those lines? If you want, I can give you some hints on lowering the amount of water that gets to the tools.
Posted 30 November 2007 - 07:57 AM
JeepinIan, on Nov 30 2007, 07:41 AM, said:
i'll take those tips!! i have a 135 psi unit w/ a 13 gal tank. not really powerful enough for the d/a and other sanders and my die grinder runs it dry; but for most ratchets, impact guns and nail guns, it does the job fine.
Posted 30 November 2007 - 07:58 AM
Gus
Posted 30 November 2007 - 09:03 AM
Do not reduce the air line size until you get to the air dryers, just before the quick connects.
Put the dryer then the oiler in line to keep the air tools lubed.
I think you can see the importance of running the lines from the top of the piping, and a drop tube at the bottom. Water is you enemy.
As for those nail gun compressors that the roofers use, you have very little choice on where to put the dryer. Oilers will do nothing w/ the amont of air hose they generally run. Oiling the tool daily, or twice daily on long use jobs, is the best.
The longer the hose, the more pressure will drop. The more bends, the lower the flow, The smaller the piping, the slower the flow.
Keep all piping the same size as the outlet form hte tank, this is usually 3/4". If you reduce the size of the pipe, th eflow will suffer. If you increase the size of the piping, the pressure will drop.
Posted 30 November 2007 - 12:23 PM
Thanks for the tips...albeit moisture in the lines is not a problem here in Scottsdale, AZ. Its almost Dec and we are up to 2.7 in of rain this year in a wet year we get 8. Humidity is LOW! I used to live in Miami...sure do like it here.
Scottsdale, AZ
e mail: click here!
