Here are the steps to replace your CJ front brake hoses. Thanks for the help Donald :!:
First U have to get the shirt on
Next, loosen the tires lug nutz.
Here is my buddy Donald jacking up the CJ to begain work.
Old brake line assy.
Remove the clip to loosen the brake hose.
Remove old brake hose. If U can't get the 3/8" line wrench on the spring side of the hard line just use a small flat screw driver & slide the hard line spring back, then the wrench will fit.
Here R the new / old hoses.
Remove the original bolt from the old hose & use it on the new one. MAKE SURE U use the new copper washers on BOTH sides.
Sorry, didn't have my camera on close up.
Install bolt in new hose w/the TWO washers & tighten down.
New hose installed & retaining clip.
Now I use a vacuum pump to suck all the air out of the system. Keep a watch on the master cylinder because the vacuum pump sucks it down pretty quick.
Reinstall the tire.
CJ Brake Hose Install
Posted 12 November 2007 - 05:22 PM
Posted 12 November 2007 - 05:40 PM
You need to retake those blurry shots. I though I needed glasses I also hope you paid Google maps royalty on that tshirt.
How much did the vacuum set you back?
Posted 12 November 2007 - 08:09 PM
If I do that then I would have to take it apart again. It was hard to see the screen on the camera in the sunshine, plus I didn't have my lighter.
Ya, that shirt is kind of old & we R making new ones that will be all together different.
The vacuum pump was a gift but U can get them @ 4wdh etc.
Posted 12 November 2007 - 10:19 PM
I thought you were going to use SS hoses to prevent fade?
Posted 12 November 2007 - 10:26 PM
15 bucks each as oppose to a lot more , I had to go w/the regular ones for now until I get my ducks in a row etc.
Posted 12 November 2007 - 10:43 PM
Gotcha, I know where your coming from. It's killing me to let my Scrambler sit in the garage waiting to do the tranny
