What's your speed?
Posted 24 October 2007 - 05:52 PM
Posted 24 October 2007 - 06:41 PM
3.5 Rubicon Express Super Flex
ProComp 33x12.5 XTerrain
Piss off a Republican, work hard, play hard and think.
Posted 24 October 2007 - 06:43 PM
Posted 24 October 2007 - 07:23 PM
2004 Wrangler
Posted 24 October 2007 - 08:04 PM
It's slow right now but hoping to get 5.0 in the future. www.embarq.com No BSouth up here.
Could get my LTop out & try it, I know it's faster then my tower.
Posted 24 October 2007 - 08:09 PM
Posted 25 October 2007 - 12:00 AM
myspace- http://www.myspace.com/baconspage
mymudspace- http://www.mymudspac...ame_bad_monday/
myjeepspace- htpp://www.myjeepspace.com/xjoutkast
Posted 25 October 2007 - 07:24 AM
'98 Grand Cherokee
Rubicon n.
Posted 25 October 2007 - 07:48 AM
This is on my hardwire desktop to router (no wifi). I have an old wireless access point attached to the router that gives me great range through walls, etc. It's kind of old and the limit on that wifi is 3k but the range goes at least one city block through anything with a solid 2.5 to 3k.
What I want to know is how Matt gets it so high and some of the others from comcast. Yet some other comcasts I see are not as high
Posted 25 October 2007 - 08:00 AM
Jim B, on Oct 25 2007, 08:48 AM, said:
Two thing will cause varying sppeds. Distance to the POP (Point of Presence) and number of active users on the cable run at the time the test is run because cable is a shared medium, DSL on the other hand is dedicated so distance is the only factor for it.
Pete
Posted 25 October 2007 - 08:06 AM
TiredPete, on Oct 25 2007, 09:00 AM, said:
Pete
Are you saying Matt has no neighbors on comcast and lives were the cows muuuuuu
Posted 25 October 2007 - 08:17 AM
Jim B, on Oct 25 2007, 09:06 AM, said:
More than likely he lives very close to the POP and his neighbors weren't very active online when he ran his test. Because cable is shared bandwidth it is usually a larger pipe in order to accomadate peak utilization. Bellsouth on the other hand is DSL, if you have FastAccess DSL Extreme 6.0 than 6Mbps is the best you will ever hope to achieve.
Pete
Posted 25 October 2007 - 08:38 AM
I have had friends also complain that their comcast really slows down at times and I guess this has to do with what you were saying. I do have to say that BSouth was up even during the Hurricanes while Comcast was down in some areas for over 4 weeks. I also got lucky during this season because at that time I had Sat TV and cable was also down for an equal time. Don't have Sat TV any longer.
I guess you can't have your cake and eat it too.
Posted 25 October 2007 - 08:50 AM
Posted 25 October 2007 - 09:05 AM
Posted 25 October 2007 - 09:11 AM
oreo, on Oct 25 2007, 09:59 AM, said:
definition per Wikipedia
A kilobit per second (kbit/s or kb/s or kbps) is a unit of data transfer rate equal to 1,000 bits per second. It is sometimes mistakenly thought to mean 1,024 bits per second, using the binary meaning of the kilo- prefix, though this is incorrect.
you should get a better result if you choose a closer test server or the Yellow pyramid
Posted 25 October 2007 - 08:37 PM
Posted 26 October 2007 - 06:22 AM
#25
Posted 27 October 2007 - 08:51 AM
#27
Posted 27 October 2007 - 09:26 AM
Now for the video proof. Get your butt a video camera and shoot the monitor while it is happening. Then upload the video to your personal JT Gallery and link it into the post. Use wmv or mpg format when you convert it. Make sure it is a small file and not a one hour movie. This will give you something to do on a Saturday morning before you go partying.
#28
Posted 27 October 2007 - 09:44 AM
#29
Posted 27 October 2007 - 10:02 AM
NonstopWJ, on Oct 27 2007, 10:44 AM, said:
Yep, I agree. Use the phone. Can you transfer the files to your computer using the phone software If you can, find out what format it is. Your Jeep Talk Gallery can accept flash, media player, quicktime and a few. Create yourself a video album. Check out the JT Gallery and see some of the videos there.
#30
Posted 27 October 2007 - 10:19 AM
Check and see if you can email the video from your phone....
