Amateur Radio
#61
Posted 04 February 2009 - 07:27 PM
Robert ...N9NQ
#62
Posted 04 February 2009 - 07:31 PM
They are set up for the better repeaters in South Florida...
Let me know. He is a BSO deputy...nice guy. He's not out to make money, only to help new Hams get on the air.
Robert...N9NQ
#63
Posted 04 February 2009 - 11:32 PM
I need a gmrs rig. It has to have programmable adjustable power levels.
Ham class. This guy wanta an elmer if there's one in Sunrise. He's from another board. I'll drop him a line about this one.
zomm zoom jr at gmail dot com.
08 JK X with extras.
#64
Posted 05 February 2009 - 05:38 AM
I'm here.
Thanks Stretchman
I am going to the FAU (K4FAU) meeting next wed. I will be talking to them about taking an exam. I will eventually want the Extra, but I want to have a little time on the air in the meantime. Any help will be great.
Thanks and 73.
#65
Posted 05 February 2009 - 02:04 PM
Unfortunately, for me, I can't make it due to scheduling ( my fault ), but I should be at the next one.
#66
Posted 06 February 2009 - 07:11 PM
Either one you want. It depends on the model.
Some can be programmed without any tuning. The power output seems to be OK. Others require tuning for resonance to get the power out. Remember the power limit for GMRS...
Robert N9NQ
#67
Posted 25 February 2009 - 08:13 PM
#68
Posted 16 March 2009 - 12:02 AM
If you only want to run an amp for vhf this is a good project that can be drived with an HT on vhf. The inductors will need some working with to get resonance in the amateur band for 2 meters.
IT uses the motorola AN955 ....1/4 watt in and appx 37 watts out.
http://www.freescale.com/files/rf_if/doc/a...955.pdf?fsrch=1
This is an easy one to build.
Robert N9NQ
#69
Posted 16 March 2009 - 01:52 PM
ZoomZoomJr
#70
Posted 19 March 2009 - 12:41 AM
The club could also get a portable GMRS repeater for added range. A couple maxtrac configured as a repeater would do the job. In the 7o cm band you can get away with duplexers wit enough antenna separation.
the article says it won't work in the GMRS band but it will with a little retune....
http://www.repeater-...trac-index.html
Robert N9NQ
below is the rescue article....
http://www.arrl.org/.../18/10706/?nc=1
#71
Posted 06 April 2009 - 02:06 PM
I found in on Ham Radio Outlet for $319. It is a full 50 watts on VHF and 40 watts on UHF. There is an out of band mod for the radio that would allow you to go on the GMRS frequencies. To be legal, you would also have to have the GMRS license and keep the power down. If you decide to go this route, be careful what frequency you transmit on. These mods are for MARS, (Military Affiliate Radio Services.) There are still some government agencies that operate on the expanded frequencies. Miami Fire Rescue and Seminole POD are a couple of examples. The mods don't say anything about the resonance of the PA (power amplifier) circuit, so I cannot say if it would harm the finals. Keeping the power down would be the smart thing to do and definitely stay away from the government used frequencies.
As I stated before, there are also a lot of HT's that are very rugged, and can take about anything you can dish out to them.
Robert
N9NQ
New class starting..
I am teaching the radio merit badge for a Boy Scout troop in Sunrise. After their portion we will go into a Tech and then straight to a General class. Shoot me an email if you are interested. It will be about a month before the classes start. No set dates at this time. We should have it figured out in the next week or so.
Robert
N9NQ
#72
Posted 16 April 2009 - 09:28 AM
http://www.arrl.org/.../15/10771/?nc=1
Robert
N9NQ
#73
Posted 21 June 2009 - 12:08 PM
http://www.arrl.org/...2009-packet.pdf
Robert
N9NQ
#74
Posted 22 June 2009 - 11:20 AM
Robert
N9NQ
No license is required....only a desire to operate on the air. This will also be low key...Jus a fun time. It will also give us a chance to look at vehicle radio and antenna setups. I have caps and can build inductors if any antennas need a better match to the vehicle.
Robert
N9NQ
#75
Posted 22 June 2009 - 07:18 PM
Bob N4GDV
#76
Posted 27 June 2009 - 06:45 AM
#77
Posted 29 July 2009 - 07:49 PM
http://www.yaesu.com/indexVS.cfm?cmd=Displ...mp;isArchived=0
$289 at HRO http://www.hamradio.com/
Robert
N9NQ
#78
Posted 13 October 2009 - 07:39 AM
http://www.arrl.org/...p=33324&dist=50
Memorial Regional Hospital
3501 Johnson Street
6 NORTH CONFERENCE ROOM
Hollywood FL 33021 10/24/2009
11/14/2009 9AM to 3:30 PM 4 Technician Class
Palmetto Amateur Radio Club
Robert Spencer
N9NQ
954-324-9449
radioclass@palmettoarc.org
#79
Posted 05 May 2010 - 01:35 PM
Next Wednesday I have a court case against Chrysler Jeep in the State of Florida Lemon Law Court.
Two meters and the 70 cm bands work OK but the HF bands are a real issue. I don't suggest trying any HF in the Rubicon. I did mount the same radio and antenna in a Jeep Patriot and it works OK. This seems to be an issue with the Rubicon / Wrangler.
I have had Jeeps all my life, but regrettably, this is my last.
Robert Spencer
N9NQ
#81
Posted 06 May 2010 - 11:54 AM
It's a shame they did not fix it. The engineers at Chrysler found the problem and said they could fix it. Some moron in management stopped them from working on it. This vehicle is probably the bad-a### of off road capability off any showroom floor. It's a shame they don't fix the problem.
For you information, the bands / frequencies affected are the very ones that do the best for intermediate range of communications. Even during the lowest of recent sunspots I was always able to have direct communications all across Florida and up into Virginia on 75 / 80 meters.
The problem was rf was getting into the vehicle air-conditioning wiring and affecting the computer. Here is the list of issues:
1. Air bag faults...did not blow but causes it to fault and probably would not work if needed.
2. Front sway bar electrically disconnects...a real surprise in a turn...
3. Traction control erratic...causes lose of control in a turn on wet pavement.
4. Check engine light stays lit most of the time...remote start will not work
5. Tachometer erratic.
6. Door chime continuous while transmitting.
7. ESB/ESR light
8. Hot oil indication faults... after recent mods from the recall...was OK before the recall.
9. Mileage affected on odometer.
10. The tech at the dealer stated it was completely "disconnecting" the computer from the vehicle.
This could have been a really great support vehicle during disasters for supporting the community. That was what I bought the vehicle for in the first place.
Looks like I'll either have to build my own Jeep with my electronics or buy an H3 Alpha. There are still a few new H3 V8's that are new but they are getting scarce. I don't see it an issue even though they are shutting down. My guess is someone will buy Hummer out after it is shut down at a greatly reduced price. Even if they don't, the major components are common in other vehicles. I test drove one a few weeks ago and it was really a great ride and lots of power with the V8.
Still undecided.
Take Care Everyone,
Robert
N9NQ
#82
Posted 15 June 2010 - 02:48 PM
The vehicle computer is in a metal case and fastened to the firewall. That alone has probably made the difference. My only issue now is there is complete silence when I am on the air. The jeep dash lights flashed all the time and the door chime was continually sounding while transmitting. It's kind of strange after two years of problems to get used to the vehicle not having an issue. I continue to look at the radio TX light to see if I'm actually transmitting now...but I have a feeling I can get used to the lack of issues from the jeep.
Take care all,
Robert
N9NQ
#83
Posted 16 June 2010 - 09:52 AM
If you do stay with CB remember. It is illegal to run an amp on 11 meters. I had the most severe issues with 12 meters. An amp on 11 meters can cause real problems if enough power is used. Even 30 watts was causing all lights to flash and the windshield wipers and other things would turn on or off by themselves...
Just be careful...you don't want your sway bar to disconnect while in a turn on the highway unexpectedly or air bag sensor to turn off if needed.
These problems could be fixed, but Chrysler said they would void my warranty if I did so. If you have a vehicle out of warranty, I'll be happy to help you get the vehicle so it does not have any problems. My Grand Cherokee worked perfect, it was the Rubicon that had the problem....
Take Care,
Robert N9NQ
#84
Posted 24 November 2010 - 08:01 PM
Soon to upgrade.
ARES/RACES Member
S&R etc.
#85
Posted 24 November 2010 - 08:12 PM
I know that there are some people out there who passed their ham tests, and I was wondering if anyone else out there was active on any of the bands.
My callsign is KD4ZKW
I am normally hanging around on 146.790. If anyone has vhf, they can normally get me there.
The Homestead machine, 147.000 is a very good repeater, and I was able to use it from
Monroe Station, or thereabouts, in case you need to contact anyone while, you're out
wheeling in the glades.
If anyone else is interested in making qso, post up your call, and maybe we can make
a sked, or even start a net.
#86
Posted 13 February 2013 - 06:50 PM
THE FT1900 IS $126 CHEAPER THAN SOME CB'S
ROBERT
#87
Posted 18 February 2013 - 02:52 AM
Help
