If you right foot keeps slipping of the gas pedal due to all of the bumps etc. while off-roading do what I did.
Get the non skid stick on stuff that they make for boating & docks & cut a piece out & glue it/stick it on the pedal of your choice, it really helps w/all that's going on while your trying to get over the Grand Canyon Jim B. :sneak:
P.S. I had to, it was just there Jim.
Gas Pedal Foot Slippage
Posted 17 May 2004 - 05:18 PM
Posted 24 May 2004 - 09:27 AM
I don't know how I must have missed this tip.
Great idea! The TJ seems to have the gas pedal kind of close to the right of the floor board allowing a bit of bracing in diaper changing situations. I'm going to have to make notice of this next time I'm out. I can see how this would help.
When I Canyon jump, as the vehicle leaves traction, I tuck my feet, & brace myself against the steering wheel until I feel the landing on the other side. Works quite well. :sneak:
Posted 02 June 2004 - 03:07 PM
Good tip Rollbar, or you can do what I did by mistake and that was to Herculine the peddle while I was doing the tub Actually turned out to be a really good mistake
Allmyt1
Its not just a vehicle...
Its a lifestyle
2005 Unlimited Rubicon Sahara Edition
RETIRED:
95 YJ
Ox Lockers, 4.88 gears, Super35 Rear, Super30 front on 33x12.50 MTRs, Revolver Shackles in the rear, S.R.S. w/ Buggy Springs in the front, Dynatrac high clearance U-bolt kit, Rubicon Express 4.5" Extreme Heavy duty lift, Poison Spyder Front tube fenders, Crusher Corners and Crusher Flares on the the rear, Avalanche Rocker Guards, Oversized throttlebody and spacer, Custom Hotwater shower, ViaAir 550c air compressor, Custom Roll cage, Wilderness Swing away tire carrier, shall I go on???
Its a lifestyle
RETIRED:
95 YJ
Posted 02 June 2004 - 03:37 PM
i looked at a website not too long ago that had a write up on pedal slipping...
they screwed in 4 small bolts on each pedal to really prevent slipping
#5 Guest_sailor4x4_*
Posted 10 June 2004 - 06:50 AM
Hey Allen don't forget Tire Wet on slick roads!
Posted 23 November 2004 - 09:40 AM
You could bolt on some HP adding chrome pedal covers, really though I got a set of sparco pedals that are a mag-alu reallx aggressive narly grip and look like old drag design. but not many out now that qualify a### more than corny. You can find some covers that look strong and stable and prep em good spray em with primer throw on some sand coat them a little more and voila
Posted 04 January 2005 - 04:58 PM
My prob isn't with slipping off the pedal, but with bouncing on/off the pedal over the bumpy stuff (especially in reverse over ex girl friends who've put on a few pounds ) Some people here dig the side of their foot into the trans hump. I think the pedal is just too light (not enough return spring pressure). I never had this prob with my carborated YJ.
David M.
2003 Sport
2003 Sport
Posted 04 January 2005 - 05:19 PM
Change the spring if U can. Use your toes not the flat part of the foot.
