TJ Cowl Snorkel Install
Posted 11 September 2007 - 10:39 PM
I do not personally know the person who posted it there, all I have is his first name (Frank) and his JeepForum.com name (Kerndone).
I am just posting his write-up and pictures and do not take any credit as this information is not mine.
This is a really nice idea if you do not want a snorkel running down the side of your Jeep.
Below is the write up:
Here is my version of the Hummer cold air intake I know its been getting more popular and the unique-ness of the mod may start taking a hit, but I think it looks great, its functional, and it was cost effective as well. I got the pieces put together over a two week span and then went to town. BTW, this is what I did and I will not take responsibility for anyone not measuring correctly and cutting holes in the wrong spot or causing any other kind of damage to his or her rig. Nor can I speak for the changes of the TJ throughout the years. Mine is finished and I hit a few bumps along the way, but it’s sealed up and it appears to be working just fine. So, with that in mind, here’s a rough estimate and parts breakdown:
-Hummer intake cap: $32 shipped (ebay)
-Buick (3.3L V6) airbox: $10 (u-pull-it yard)
-Plumbing reducer bushing: $4 (Home Depot)
-Plumbing flange: $2 (Home Depot)
-Nuts, bolts, and miscellaneous items: $10 (all stainless hardware from Lowe’s)
-Flexible 3” ricer air tube: $20 (Autozone)
-Paper air filter: $7 (Autozone)
I opted to use a buick airbox as it has been used previously by fellow jeepers. Not to mention I think it gives it a clean look under the hood. The negatives to this route are you will need to remove the airbox to change all the plugs and you will need to “route” the dipstick when checking your oil and your trans fluid. Oh well, I will survive. BTW, here’s some reading on that mod…
Ok, on to my airbox install; I'll explain what I did and then rapid fire some pics. I removed the old airbox and cut the intake tube. I used a 3 to 2 rubber bushings to connect the intake to the new box. The problem was I needed to whittle down the i.d. of the busing since the Jeep’s intake tube is roughly 2 5/8. After that, I did a test fitting with the box and got some scrap metal for a bracket.
For the bracket I opened up the bottom end and attached that to the motor mount. I twisted and bent it with some pliers so everything would line up.
The next step was cutting through the firewall. I measured twice and cut once. You can see how close I got to the ground! Like I said, measure TWICE and cut ONCE!
Ok, at this point you can run some flex tubing into the cowl for cooler air and call it a day. If you choose to do so, it will look something like this under the hood.
I wasn't done yet, but this first part concludes the “Buick cold air intake” portion of the write-up.
Alright, so you want to do the Hummer intake, well there are some things in the cowl you will need to take care. WARNING!!!! THIS WILL BE A TIGHT FIT TO GET THE INTAKE TOWARDS THE EDGE. I had to apply some pressure to get the cowl cover attached and screwed in.
Back to the write-up; the A/C/Heater intake is right under the cowl where you need to cut the hole. Now you can just mount the intake closer to the middle, but I think it looks cleaner at the end of the cowl. So you will need to remove this cover and discard it (research tells me that this piece isn't on A/C equipped TJs until 1999) or do something like I did. So here it goes…
This is the pic of the cover. I wasn't going to let that stop me, so I measured a few times and cut a hole in the cowl cover quickly with a 4" hole saw.
I then trimmed up the plumbing flange and test fit that in the cowl cover.
I trimmed up the fresh air intake and then test fit the flex tubing as you can see in this next pic.
I then used the dremel to cut trim the black cover so I could re-install that and keep water out of the A/C/Heater unit. I opted to use it since DC designed it and started using it, there must be a reason. To make my “new” cover, I used some aluminum air duct (thanks for the idea Dad) to close it up. I riveted that in place and sealed it with silicone so it would stay water tight. In the next three pics you can see how I trimmed the cover, closed it with the air duct and finally how the flex tube sits next to it.
So, I have it all ready to go. I chose to use some nylon spacers, trimmed to account for the bend in the cowl cover, in order to level the plumbing flange. The end of the cowl cover slopes down, so the inside edge needs to be a little further down. I also clearanced the right edge of the flange so the tube would have some space after the bend. To attach the flange to the cowl, I purchased some stainless bolts and 4 stainless acorn nuts. I drilled the holes through the cowl cover, sealed them up with silicone and bolted it all together. Now, to explain myself a bit more, the flange I picked up is 4" O.D. so I needed a small piece of 4" I.D. PVC to connect the Hummer intake cap to the flange. You can see that small section I used in the pic, it’s actually ABS and I decided to leave it black.
In the subsequent pictures, I am just showing the 3” flex tube coming through the flange. I have not added the ABS collar.
Ok, I will say this again; the cowl cover does not fit as nice anymore. It’s pretty cramped in the corner since the cover slopes down and the cowl slopes up. No to mention the flex tube needs to make a 90 degree bend in that area. I was able to press the cowl in place with just enough force to make me comfortable with the clearance I have. There is no doubt the flex tubing has deformed a bit and the cowl cover is slight bulged at the corner. This isn’t noticeable, nor does it concern me. I just want everyone to know that there is not any extra room…in fact, IMO there isn’t enough room, but you can make it work with a little effort!
Finally, I trimmed the ABS “collar” to lay flat over the flange and I then drilled a hole through the ABS and the flange, inserted a threaded tee nut from the back and used an allen head screw to prevent anyone from just walking off with it. I haven’t yet installed the hose clap on the intake cap, but I have some time to do that.
Oh, and I measured twice and cut once…check out this clearance (I got a little lucky I think)!
Phew, there it is...a pretty complete write-up. Once again, these are the steps I went through to install my version of a Hummer CAI. I choose to call it a CAI rather than a snorkel because I am not a commander of a submarine. However, if I really want, I can run a longer length of ABS and raise the intake cap a couple feet from the hood. Either way, its higher than stock and its colder air for the engine. Feel free to critique this mod and ask any questions you may have. I'll browse through this later and make any corrections as needed. If I did miss something just let me know.
Oh, with the design of the Hummer intake, the change in the direction of the air and maybe even the flexible tubing, there is a new sound when you really get on the throttle. IMO its a "fun" sound and I'd rather hear that than a loud exhaust.
-Frank
This will be a good mod for this write-up. Use this snorkel head instead of the Hummer style. Thanks JeepinIan for this find.
4" Tube Would work.
Posted 12 September 2007 - 07:08 AM
The only thing missing now are some pictures of the actual head being installed but we will let JeepNWilly do that when he does his.
Maybe even a CJ to follow....
I've seen other setups, not snorkel but in where Jeepers route the air tube up the cowl and modify the cowl itself to have a bit of more air volume. Can't remember where I saw pics of this. I know my long time pal who passed away (TJRon) had it this way on his Jeep so maybe it was his, I would have to dig around.
Posted 12 September 2007 - 07:15 AM
Jeepdew
04TJ & 88MJ
Posted 12 September 2007 - 07:27 AM
'98 Grand Cherokee
Ru•bi•con n.
Posted 12 September 2007 - 11:02 AM
Yup,
I plan on doing this to my TJ, I am going to work on gathering all the necessary parts. I am also hoping to find a replacement cowl so I do not have to cut my own I have seen them on ebay for cheap but hoping to find one locally. I am also thinking of keeping the existing airbox to make this mod as inexpensive as possible
Posted 12 September 2007 - 11:42 AM
JeepDew, on Sep 12 2007, 08:15 AM, said:
Jeepdew
Mike,
TJ (Toni F) runs this without a problem or no loss of power on his TJ. He has told me of having water over the top on some of his local crazy outings to the point that the Snorkel Head was covered with water and not a problem.
I told him if he starts thinking about staying submerged and becoming a submarine he might actually have a problem.
Of course he rides with a forgiving manual tranny and makes sure when he is out of the trail to check fluids depending on the wheeling just in case. He usually changes and flushes all when he gets home. All his vents are up and electrics are sealed... last time I saw him anyway.
Posted 12 September 2007 - 12:54 PM
Jim B, on Sep 12 2007, 12:42 PM, said:
TJ is running one of the dust ejectors.
Posted 14 December 2007 - 03:58 PM
Posted 14 December 2007 - 10:50 PM
Posted 15 December 2007 - 12:23 AM
38.5/14.5 tsl sx
Ballistic fab beadlocks
cobra 19 cb
superwinch 9500lb winch
8 inch fabtech rock crawler kit
3 inch body lift
and more...
Posted 15 December 2007 - 07:21 AM
MudTime, on Dec 15 2007, 12:23 AM, said:
Nothing, no water will get in depending on the snorkel head he used. I know the one that TJ is using on post #7 will not. The one on the picture at the bottom of post #1 looks good, not too sure about the one the red Jeep.
If you do a search on snorkels you will see other topics with the Cat head and others that are similar.
If I was ever to switch out my current snorkel setup which works great now, this is the way I would do it.
These pop corn popper type heads are excellent. The Australians use them a lot and you will also see them on Landrovers.
Below is my current snorkel setup.
Posted 04 January 2008 - 04:52 PM
...and that tree in Ocala
