Convert YJ Grill To a TJ Grill
Posted 24 August 2007 - 10:00 PM
1) removing the fan shroud by unbolting it from the radiator
2) removing the radiator by unbolting it from the grill
3) unbolting the inner fender well bolts that hold the grill in place (8 each side)
4) loosening the upper rod supports from the grill
5) removing the body mount bolt on the underside of the grill.
6) removing the wiring harness from the grill
Now that the YJ grill is gone... Slide the TJ grill in to place.
You may notice your fenders may bow out at this point. This is due to the fact the TJ grill is wider at the bottom. This is not a big deal. Take a body hammer and gently pushed the fenders back along the grill line until everything was square. You don't need to worry about being too exact at this point. The fenders will pull back nice and tight when the inner fender bolts are back in place.
Now bolt the lower body mount to the bottom of the grill.
The body mount should line right up. The bolt hole on the TJ grill seems to be in the same location as the YJ's. Be sure to keep the OE shims in place.
Now you will need to remove the upper rod support brackets from the YJ grill
To do this, drill out the 2 spot welds on the bracket and use an angle grinder to cut the other welds. You should be able to break them off with a hammer after that.
Now you need to take the upper support brakets and weld them to the TJ grill.
Just center the brackets on the existing bolt holes on the YJ grill and weld away.
At This point you will need to move the adjusting nuts in or out until the top of the grill is in the desired location. Set it so the top of the grill sticks out a touch like on a stock TJ. This makes the gap look a little less noticable as well.
OK, Now we need to drill new holes for the inner fender bolts
This may take a couple of tries to get the holes in the proper location. There will be 3 bolt holes on each side of the TJ grill you will need to drill for.
Now that you have your inner fender bolt holes drilled you should be able to put in the bolts. The fenders that are spread out and dented from hammering will now suck in really nicely after you snug the bolts.
At this point, you can take your original wiring harness wiring harness off the YJ grill and pop it on the TJ grill lights.
That's about all there is to it of course you will need to do a little hammering and bending here and there, but hey.... It's a jeep. That's what it's for.
What about the front signal lights?
Grab a set of 2 3/4" round trailer lights from a local parts store. Measured the diameter of the light bezal and used a correct sized hole say to cut two circles in the TJ grill. Be sure to apply some paint over the bare metal after the cut.
Take the OE square blinker housings and cut the back end of the light (where the bulb plugs in) and used contact cement to mate it to the round lens. The OE wiring harness plugged in perfectly after that.
(a final picture painted and with the signal lights installed.)
This may look like a big project since the pictures show the jeep undergoing a full restoration, but the process really isn't that bad. You could do it over the course of a weekend without any body work or paint.
The end result looks quite nice & better that that SQUARE stuff in my opinion. There are two small gaps in the upper corners of the grill due to the fact that the TJ grill is a slightly different shape than the YJ hood. The gap is there, but not that bad.
Compliments of Jimeny Krickets.
Posted 05 August 2009 - 06:40 PM
Rollbar, on Aug 24 2007, 11:00 PM, said:
YES!!! I needed this!!! I'm so excited!!! Is this really for real?
Every time I've asked, and racked my brain trying to figure out something, and pictured custom making a grill (w/ round lights), I just got the nods Come to think of it, I bet you the came from SQUARE LIGHT FANS!!! Shame on all of you!
Now, if you are doing the job yourself, which I'm going to need to being SQUARE LIGHT FANS that tricked me are not my friends...how much are you looking at for the grill and all the parts necessary (out of my pocket). Sorry to ask this, but where would I get the grill, and I noticed the one in the pix is chrome, lets say I want it the color that I re-paint the jeep with? Any other info would be a great help.
Thanks Rollbar
1987 YJ7TJ
That's all folks!
Posted 05 August 2009 - 09:28 PM
Posted 05 August 2009 - 09:58 PM
Posted 06 August 2009 - 07:01 AM
Posted 06 August 2009 - 07:23 AM
LrdJeffson, on Aug 6 2009, 08:01 AM, said:
Just to get the U.G.L.Y. (You ain't got no alibi, U ugly) off the Jeep and the look of a more modern Jeep.
Now U said it, something great and performs great
Posted 06 August 2009 - 07:37 AM
I'd do the CJ grill and front clip, but have to go with used and I'm tired of seeing the rot on all the CJ's I look at. And forget fiberglass.
1987 YJ7TJ
That's all folks!
Posted 06 August 2009 - 07:54 AM
Gutsy, on Aug 6 2009, 08:37 AM, said:
Ya, they do sell a front fiberglass clip and it tilts forward if you want gaining access to the whole engine area for ease of working on it.
P.S. & the rot, that's just aging with beauty
Notice the front clip picture.
My friend in PA. He has been on the cover of Summit etc. & this Jeep turns some serious RPM's/ET's
best ever 11.997 @ 107.93 mph in 1/4 mile on 33 x 10.50 slicks and 4" lift / 7.53 @ 90.84 mph in the 1/8 mile
Posted 06 August 2009 - 11:29 AM
