For some reason A lot of new jeepers don't know the have to go to neutral to shift in to 4 lo'
If you have a automatic transmission or a manual you can shift into 4 hi in any gear but to go in to 4 lo you must be in neutral to go into 4 lo..
I hope this helps. The last 5 times I have been on the trail their is alway at least on new jeeper that did not know how to do this and said the 4 lo was not working..
Please if your on the trail and you are not sure what to do ask some one for help.. That is one of the good things about a club like ours..
Engaging 4 Wheel Llow
Posted 31 July 2007 - 04:45 AM
CEO of Black Sheep 4x4s
Posted 31 July 2007 - 05:37 AM
You know I just found out how SHift on the FLY works I have been wheeling on form of vehicle or another since I was 15. I have never locked in 4 High with tires rolling. Always from a stop in Neutral. Prob because that was ground into me.
Miller, Jonathan
"Baby Kong"
2002 wrangler X
Enough my wife stays pissed at me!
Lakeland Jeep Club
"If I break it. It's an excuse to get what I really want right?"
"How many jeeps do we really need in the driveway at one time?"
"Baby Kong"
2002 wrangler X
Lakeland Jeep Club
Posted 31 July 2007 - 06:49 AM
Well if your going to sift into 4 low and you have to be in neutral try to have your vehicel rolling just a little bit when you get in to neutral and it will go into 4 low easier
Tim
'98 Grand Cherokee
Ru•bi•con n.
'98 Grand Cherokee
Ru•bi•con n.
Posted 01 September 2014 - 05:55 PM
good tip.Took me a little while to learn on the fly as described in owners manual.
