Proper Winch Usage Safety Always
Posted 30 April 2007 - 04:36 PM
I anchored the rear end of my jeep to a large oak tree using chains and a 4" strap. I then tied a large rope from work around the tree. I then hooked my winch to the rope. To reduce the stress on my winch I used a snatch block in line. Everything was going well I pulled out the first stump and then went to the next.
The second stump was a little bigger and a lot of tension was being applied. I was standing outside my jeep using the controls watching the rope, cable and all the connections and then bang the rope breaks. Now that was bad but not as bad as when I saw my jeep going back wards across the yard at a very high rate of speed.
Due to the tension on the rear 4" strap it accelerated across the yard and stop when it hit the large oak tree. Some of you may remember I have a JEEPERMAN rear bumper with the tire carrier that hold the HI lift jack. I had the tire carrier open (lock Open) and the rear door open with several items in the back Tools, shackles, lug wrench, first aid kit, etc. Well when I got back to the jeep to see what damage it had done I found the end of my HI lift jack had speared the tree and it was about 4" in the oak tree and bent. Most of the items in the back of the jeep were thrown clear of the jeep and some I couldn't find.
I tried to drive it way but due to the jack being stuck in the tree I have to winch my self out to the tree. What did I learn from this? Never use you winch unless someone is in the jeep with there foot on the break!! I had been using my winch saver and a old towel just in case this happened but did think about were the jeep mite go if it broke. PS: I need a new HI Lift if anyone is selling one.
Posted 30 April 2007 - 05:38 PM
P.S. a parking brake will help some.
Posted 30 April 2007 - 06:58 PM
33x12.5x15
15x10
Posted 30 April 2007 - 08:23 PM
Posted 30 April 2007 - 08:36 PM
everything else can be replaced
Posted 01 May 2007 - 06:53 AM
'98 Grand Cherokee
Ru•bi•con n.
Posted 01 May 2007 - 07:46 AM
The rule of thumb is to always use a healthy cable... rope for some with rated straps or chains. Your biggy here was to use that rope from work not knowing what the snap capacity (if any) was. I've also seen a few times the rated winch ropes brake because they will fray and the user continues to keep it in service because of the cost of replacing. I would have used one or two 2" 30 foot rated straps. Will this guarantee 100% safety... heck no!
To be Human is... No matter what, we all make mistakes no matter how hard we try. Just glad your ok Lenny. Good of you to discuss this with everyone.
Read my signature.
Posted 01 May 2007 - 04:29 PM
Jim B, on May 1 2007, 12:46 PM, said:
Your correct Jim it was one of those things you hear about but something I didn't think about. Thats why I made this post just to give others a heads up and make them think about what they are doing when using a winch.
Well it won't happen again I got a steel cable certified to 7 ton going on the tree this weekend. That tree is coming out of the ground.
And my straps are rated and in good condition I should have know the rope would break. That won't be a problem any more. If the rope, sling, or strap isn't rated it wont be used on my jeep. Also someone or myself will be on the break.
Posted 01 May 2007 - 04:35 PM
Posted 01 May 2007 - 04:55 PM
Lenny, glad you are O.K.
And, yes, I think we all learned something........who would have thought the Jeep
would have gone backwards.
SFJC, Jeep Club Advisor
Posted 23 July 2007 - 05:58 PM
2004 Wrangler
Posted 08 May 2008 - 07:17 AM
Under Construction, estimated completion date, June '09
Posted 08 May 2008 - 03:56 PM
Posted 09 May 2008 - 02:04 PM
Rollbar, on May 8 2008, 04:56 PM, said:
you have a point as well. I guess the best remedy would pertain to the situation at hand. From my experience when ever i had to anchor myself i always TRY to put my self against a tree on the front bumper. I have even put myself against another jeep!. I dont believe the straps would actually take out brake lines and such unless you have knots in them. again, its just an opinion. to each there own. but keep in mind that its easier to replace a brake line, cable, etc, then to straighten out ur chassis.
my 2 cents
Posted 24 May 2008 - 11:09 PM
