Custom 3 Link F/R Animal Garage Design
Posted 21 March 2007 - 08:34 PM
History lesson
For some time now I planned on upgrading my front axle to a HP D44, at the same time I was going to upgrade my rear D44 w/ disk brakes and 33 spline shafts and three link it. Well on my trip to Superlift last June I almost completely ripped my front track bar mount off of my front axle, so I spoke to Ruben about going away from a track bar up front and also and 3 linking it. Well he was all for it so 3 months later it's almost done.
Here is the old factory setup
Raising the rear control arms on the axle for clearance
Completed drivers side rear
Removing the rear track bar mount from the frame
Checking the new bumpstops (coil bucket was moved on the axle from the factory location)
Making the new rear shock mounts for the axles
New 1/4" shock mounts compared to 3/16" currie
Full compression and full drop
Rear 3 link mount on the axle
Building the upper 3 link
3 link mounted to the JEEP
Rear axles, locker, and disc brakes
Well thats pretty much it for the rear. If you want more pics go to my website as there are way to many to post here.
Rockrawlinsahara
Pics of the front are coming soon.
Lee
Posted 22 March 2007 - 07:14 AM
Good report and I like the fabrication shots of the mounts!!!
DAYTONA BEER POLICE MEMBER #6
'04Liberty--3.7L, auto, 4x4
Joe
Posted 22 March 2007 - 07:28 AM
'98 Grand Cherokee
Rubicon n.
Posted 22 March 2007 - 07:49 AM
I like the way the capture attachment of the 3 link in the rear on top of the pig was done vertical instead of horizontally. 99% of the others that I see out there are done horizontally. I also have mine vertically. While there have been only a few reports of failing horizontal installed joints or heims, the brute strength geometry of these and how the arms work are while they are installed vertically.
The rear axle support looks awesome and bullet proof, I can't wait to see it in person. The only thing I would have done different is the angle of the Y. In a perfect world 90 degrees (45 on each side) is the ideal. Since we do not live in a perfect world when I did my research a few years back (with regards to getting swirly on the turns and snaking side to side while at different speeds) was to stay at a minimum of 60 degrees (30 on each side) at the Y. The only way I could accomplish this was to mount the uppers on the frame rather than at the skid. In order to do this you should have at least a 2" body lift so it could work. If I'm not mistaken I'm at around 34 degrees on each side for a total of 68. Most do it they way you have it because it is no biggy and we have to be careful anyway when our Jeeps take the payment since they are not really built for the street any longer. Since I have an anal problem I had to go the extra step.
I can not see the parallel degrees between the upper and lower rear arms. This has to do with pinion plunge, as long as you are under 70 degrees at either side (which by the sneak angle on some of the pics I looked at it seems so), I would be happy to take your keys and drive the Jeep for you. Please advise at your earliest convenience. Mr. Animal always out does himself.
All this said articulation is good, but it has to be control. One of the reasons that ramp queens do not do well in real world actual rock trails. The ultimate goal for me was to have a free working and articulating controlled axle at both ends.
Now, hurry up and finish so I can see the front, I'm sure it will be a beauty.
Btw, nice album.
Posted 22 March 2007 - 09:50 AM
x 100
i seen it one day at animal garage, bad a### !!!
Posted 22 March 2007 - 12:18 PM
STOUT!
Posted 22 March 2007 - 05:00 PM
Jim as soon as I get a chance i'll find out the angles for ya.
Lee
p.s. the front pics should be up by tomorrow night. hehehehe
Posted 23 March 2007 - 09:02 AM
I also noticed in your gallery that you have a cross memember to support the atlas even with the RE skid plate dropped. That's one of those nice, but unseen and usually unappreciated improvements. I wish I could get my hands on one of those. I'm still scratching my head on how I'm going to drop the tranny pan to change the filter while supporting the drive train without the t-cae skid installed (which is holding everything up).
2003 Sport
Posted 23 March 2007 - 04:37 PM
both ends of the 3 link are adjustable, I have johnny joints at the frame and a huge heim at the axle. as far as the brake lines are concerned we put braided lines on there however I don't have any pics of them at this moment. Ruben did that crossmember last year and it has been a lifesaver so much easier to work under there now. I'll try and find some pics of the brake lines in the other 200 + pics I have of it.
Lee
Posted 23 March 2007 - 06:16 PM
Posted 24 March 2007 - 09:08 AM
Lee
I saw the single heim at the axle. What I was trying to describe was that at the axle end, your links are welded (fixed length) and the one adjustment is at the heim. On mine, I have a big joint at the axle (which is not adjustable), and the links are threaded. Does that make sense?
I think the advantage you have with your system is that the lateral placement of the rear axle is more easily adjusted because only the frame end is threaded on the link. So, you only need to turn one link to move the axle laterally without really affecting pinion angle. On my system, I have to turn both uppers equally but in opposite directions to move the axle laterally without affecting pinion angle. To adjust your pinion angle, you just un/screw the heim at the axle. I can't do that with Troy's system.
Hope you enjoy the new links, they look awesome.
2003 Sport
Posted 24 March 2007 - 10:47 PM
Rollbar, on Mar 23 2007, 06:16 PM, said:
Hurricane F134 (Whoppin' 75 HP
33x12.5 15 BFG mt
Posted 26 March 2007 - 06:53 AM
YJWhenUCanTJ, on Mar 23 2007, 09:02 AM, said:
Having a manual tranny I usually support with a jack stand and do it all on the ground. Might be a bit tricky with an auto but I'm sure if you can find a 6 ton jack stand (use wood if not tall enough), you can find a crevice or two where to support.
Mr. Animal has to bend a tube for my support on the tube fenders (when I get to it) , I might just have him make me a support just like Lee's. Has to be done right because you need to spread the frame just right so that the 3rd middle plate does not hang up. If you never dropped your middle plate you will soon know what I mean. Comes down easy but it's a pita when putting it back up.
Never fails, we always have a forum mudder hanging around.
Posted 30 March 2007 - 01:30 PM
Jim B, on Mar 26 2007, 07:53 AM, said:
Yeah right.... how long has it been now.... :sneak:
Liking the crossmember, and the rear link. Waiting for pics of the front. That damn RE skid sure is a PITA to put back up.
...and that tree in Ocala
Posted 04 April 2007 - 07:32 AM
I get not mercy around here. ..... Soon
Yes, detail pics of the crossmember, I would also like to see a bit closer the front upper arm tie in. Have not seen this in person yet. I think before you take it home you out to stop by the Bat Cave so I can take a look at it.
