Calculators, Bulletins, & Manuals
Posted 05 August 2004 - 08:49 AM
Speedo Converter
Find new Gear Ratio with new tire size
Find Overall Crawl Ratio
Find MPH
Find RPM
Convert P-Metric tire to Tire Diameter inches
Power Conversions by PowerStream.
Convert Watts to Amps
Convert Amps to Watts
Convert Volts To Watts
Convert Watts to Volts
If anyone has anymore that are different, let's post up the Links!
Posted 05 August 2004 - 09:12 AM
Speedo Gear calculator This is for the gear in the T-case. Very helpful.
These should be helpful.
2004 TJ X
2.5 RANCHO Lift
R.E. Quick Disco's
TxT Front Bumper
Jeeperman Rails/Steps
M/T 33x12.50
(OIIIIIIIO)
Offroad Technology rear bumper and tire carrier
Posted 19 December 2006 - 09:10 PM
Posted 21 December 2006 - 01:01 PM
Posted 21 December 2006 - 01:15 PM
superdave1984, on Dec 21 2006, 02:01 PM, said:
Look @ the color chart,
1. Hwy-Yellow-Hwy Driving.
2. Daily Driver-Blue-Best Overall Performance.
3. Towing & Power-Poor Fuel Economy.
P.S. The numbers are the RPM's the engine is turning.
Posted 25 January 2007 - 09:23 AM
raise up the axle so the tires are off the ground, put the x-fer case in neutral, tranny in neutral. mark the bottom of one of the tires. Spin the driveshaft and count the number of revolutions of the driveshaft it takes to turn the tire one revolution. that will get you a good estimate of your gear ratio.
for example, if you have to spin the driveshaft 3.5 times for the tire to make one revolution, your gear ratio is probably 3.55:1. If it takes you 4 turns plus just a hair, 4:10:1. HTH
2003 Sport
Posted 25 January 2007 - 01:51 PM
Posted 25 January 2007 - 05:26 PM
Posted 03 March 2007 - 03:29 AM
Rollbar, on Jan 25 2007, 01:51 PM, said:
That's correct. If the diff is open, or unselected if it's a selectable locker, you'll need to rotate the tire twice to get the correct ratio.
If it has an auto locker or working LSD, one rotation will do the trick.
Posted 20 August 2007 - 10:05 PM
www.csgnetwork.com/automotiveconverters.html
www.5speedtransmissions.com/techref.html
www.gearsareus.com/gear%20talk.htm
Posted 20 August 2007 - 11:28 PM
Posted 28 August 2007 - 10:04 AM
June 26. 1988 - August 29, 2008
2005 Dodge Neon SXT - Full ACR suspension swap, 2" lowering springs, 17" SRT rims, CAI, Cat - Back, 5 speed, stage 2 clutch, strut tower bars, sway bars - Autocross Car/Daily Driver
1990 Jeep XJ - Gettin ready to make a scene.
www.FortMyersRacing.net
www.SWFLRacing.com
www.SouthernMudding.com
Posted 31 August 2007 - 12:50 PM
Jeep VIN Decoder 1.64
Not sure on the accuracy but some of you can test and report.
1961-1993 Vin Decode for Equipment
Jeep Vin Info Up to 2004 for TJ, XJ, YJ, CJ, WJ
Jeep Vin Info for listed Models.
In combination with vin correctness and some of these links, maybe equipment info can be had.
Not sure how good these will work but try it and let us know.
This one you have to download.
Dirt Road Jeep Vin Decoder
This one is on line and is good from 1982-2005 for all of Chrsler.
Allpar Vin Decoder
Jeep VIN Reference Guide
Posted 01 September 2007 - 09:57 PM
Posted 22 October 2007 - 08:01 PM
www.SWFLRacing.com
Posted 16 November 2007 - 07:57 PM
Posted 14 December 2007 - 05:47 PM
Here is how to do it manually with a carry me calculator.
Ramp Travel Index is based on climbing a 20 degree ramp with one tire while keeping the trailing tire in line.
At the point where any tire begins to lift into the air is where it's calculated.
The distance of up travel up the ramp without losing contact with the ground.
1. Measure from the bottom of the ramp to the center of the bottom of the tire (use a plumb from the hub to find center or some type or right angle).
Measure from the leading edge of the ramp to the center of the hub on the ramp.
2. This distance traveled in inches is divided by the wheelbase in inches and multiplied by 1000.
What this gives you is a percentage of travel up the ramp in relation to your wheelbase.
For instance, if a vehicle with a wheelbase of 94"s, travels 62"s up the 20 degree ramp, then the RTI would be calculated as:
62" divided by 94" x 1000 resulting in a score of 659.
Posted 29 December 2007 - 04:09 PM
AX-15 Service Manual
Jeep TH-400 Jeep Transmission Manual
Jeep T-176 Tranmission Info
Tie Rod Flip Kit Install
Posted 02 March 2008 - 10:39 PM
Posted 22 October 2008 - 02:25 PM
If anyone wants my updated file (has a few more fields with personalized information for the ramp driver) that you can load in any Win OS Computer and print to any printer.... Private Message me. You do not need to be connected to the Internet to run this.
It will cost you dinner for two.
Posted 01 December 2008 - 05:57 PM
Posted 05 December 2008 - 07:59 AM
coonbuster, on Dec 1 2008, 05:57 PM, said:
I have a spreadsheet .xls that I've been using for a very long time that asks tire size, gear ratio, TC and Tranny on each gear and it gives you a nice print out but it's very basic. You must know this information though.
This calculator that you posted is much nicer and complete in that it takes now stack configuration and it gives you a drop down menu for the different Trany/TCs out there. Nice find
Posted 13 January 2009 - 09:12 PM
Posted 07 February 2009 - 09:51 PM
#25
Posted 03 June 2009 - 12:21 PM
Needed one for the Dodge Diesel. Looked at the Jeep Manuals and they had quite a few.
The PDFtown link files were corrupt so I had to go to the User-Manual.org and got it. Could have been a bad upload.
User-Manual.Org
PDFTown.Com
