Check your tire pressure DON'T FORGET THE SPARE TIRE!
Posted 05 July 2006 - 02:21 PM
I try to check my tire pressure, about every other fuel fill up. And, today, for some reason, I decided to check the pressure in the SPARE TIRE..........it was all of 10 pounds.
So, when you check your tire pressure...........be sure to also check the spare.
1982 CJ-7, 31" tires, 12,000 lb. Ramsey Winch.
SFJC, Jeep Club Advisor
Posted 05 July 2006 - 06:19 PM
Great info..
I'll have to do that ...
When I get a spare...
New tires coming soon so no spare right now....
John
Member of:
Member of:
Posted 05 July 2006 - 07:53 PM
I'm still lookin' for a 32 or 33 used AT or MT as a spare...
Posted 05 July 2006 - 07:56 PM
If U fill your spare up to the proper poundage & ride in it for about three day's it will stay inflated & not loose pressure for a long time. Been there & done it. It reseals the tire to the rim etc. & makes the tire ply-able again.
Posted 06 July 2006 - 01:21 PM
I'll check the tire pressure on the next fill up.......and if it has gone down, I'll try your tip.
Posted 08 July 2006 - 08:43 AM
Hogwash, on Jul 7 2006, 10:16 PM, said:
You mean if you have a spare
All my vehicles have spare tires. And, I do carry a small electric plug into the cigar lighter air pump, plus tire plugging kits.....just in case.
I checked the spares on both of them, and the one that went down to 10 pounds was checked again...........and the inner portion VALVE?) of the valve stem was broken, and replaced. The valve stem is metal, not rubber.......and it did not leak air.
Just trying to get prepared, just in case I get a flat tire.
Posted 28 July 2006 - 03:42 PM
I have a cherokee i dont have room for a spare Yes i know !
