Dyna Beads tire balancing
#31
Posted 10 May 2006 - 12:34 PM
No matter where you go there you are
#32
Posted 10 May 2006 - 03:05 PM
Greenlantern, on May 10 2006, 08:30 AM, said:
Green,
This is poor customer service. You need to post this info on the Vendor forum along with your scenario and refer the company to this thread along with the thread on the vendor forum.
I see that there are other satisfied people without problems and this should also be noted, but the kicker of this matter is that the company would not work with you in solving your problem especially when it could benefit them as well as showing their customer service.
#33
Posted 10 May 2006 - 03:43 PM
All they had to do was send me some xtra beads and if it did work hey- my loss. But they should bare some responsibility with their product too.
PLus my rims are not bent, the tires are brand new 31" only. etc...................
#34
Posted 10 May 2006 - 05:07 PM
Incidentally, what wheels do you have? Are they steel or the stock aluminum or other cast aluminum?
IAN--the problem is I have EVERY KIND of weight on my tires. Mostly the FLAT ONES on the inside of the wheel rather then the old fashioned clip ons so I dont think it would be easy to figure it out. john
#35
Posted 10 May 2006 - 06:53 PM
John, on May 10 2006, 05:07 PM, said:
Then it is time to remove all the weights and start over. You probably have too much weight and they are working against each other.
#36
Posted 10 May 2006 - 07:21 PM
Will see what customer service feels about returns due to thier lack of customer support given to others !!! :sneak: :sneak:
Pics of my Wrangler : http://www.wrangler-renegade.com/
____________________________________
Help Humanity with your computers idle time, help find a cure for cancer among other illnesses !!
http://www.foldingathome.info
NEXTEL 158*81*25887
#37
Posted 10 May 2006 - 08:14 PM
steel black 15x8.
#38
Posted 10 May 2006 - 09:05 PM
I-It
S-Simple
S-Sweetheart
Just like the proven CJ, wheel weights are your friend.
P.S. I wonder @ what effect caked on mud would have on the internal beads. W/regular weights @ least you can still drive home.
#39
Posted 11 May 2006 - 10:02 AM
I have not yet taken off any of the wheel weights.
'98 Grand Cherokee
Ru•bi•con n.
#40
Posted 11 May 2006 - 10:26 AM
#41 Guest_Livefree_*
Posted 11 May 2006 - 06:49 PM
I wish I would have keep my weights on like Tim. I still have a small shake at 70 but I way better then without the beads. I will say that from 0-65 it rides so much better. I plan on putting 35's on my jeep and I will use dana beads on them. I am very happy with the 0-65 ride now.
#42
Posted 03 June 2006 - 06:27 PM
Did anyone notice the purple nail polish and fingers in Tim's original post? Last time I saw Tim, he was a young male. What's up with that?
2003 Sport
#43 Guest_Livefree_*
Posted 03 June 2006 - 06:53 PM
#44
Posted 15 June 2006 - 02:59 PM
I have NOT had any personal experience with DYNA BEADS, but I just got the latest monthly issue of the South Florida Antique Automobile Club magazine and they have an article in it about a similiar product.
He ordered a kit from www.innovativebalancing.com for $35.46 and it included 4 valves, a bottle with a tube neck, and a bag of miniature balls or beads. He ordered 4 oz. for each wheel.
This one bit of INFORMATION, may or may not solve some problems with larger, more aggressive tires, but he says this product is often used on large trucks. In the instructions, it states: "Take all the weights out of the wheel, marking down their location and how much weight was inside and outside. Don't discard them, you may need to install them back in the same place. Do the installation on the tires of only one axle."
"If, after installing the beads, and road testing over 75 mph, if there is still a balance problem, re-install the weights on one tire of the axle and re-test. If that doesn't cure the imbalance, try removing the weights, and re-install the weights on the other tire.
After testing, and with no imbalance problems, then install the beads on the other axle."
Another GEM of info was to order about the same weight of beads as the weights on a wheel.
He stated that it worked on his old ANTIQUE vehicle. Also, the product is GUARANTEED to keep the wheels balanced all the time and at any speed.
SFJC, Jeep Club Advisor
#45
Posted 15 June 2006 - 03:57 PM
Hmmm......this is the same product......DYNA BEADS! I went to the website.
Anyway, hope the previous posts info is valuable.
#46 Guest_Livefree_*
Posted 15 June 2006 - 04:15 PM
#47
Posted 16 June 2006 - 06:21 AM
'98 Grand Cherokee
Ru•bi•con n.
