$10 alarm
Posted 27 March 2006 - 07:24 AM
I found this this weekend. Thought it might be helpfull to someone. Its a great idea.
TJ Alarm
He has many other great write ups on his website also. Ive bookmarked this website
'98 Grand Cherokee
Ru•bi•con n.
Posted 27 March 2006 - 08:21 AM
Posted 27 March 2006 - 02:49 PM
Posted 28 March 2006 - 08:31 AM
-alex
-06 cummins 3500
www.southeasthay.com
Posted 03 April 2006 - 12:21 AM
...and that tree in Ocala
Posted 08 July 2006 - 07:03 AM
Bevis, on Apr 3 2006, 12:21 AM, said:
Hahahaha. A rat trap for a rat!!!!!
good one.
DAYTONA BEER POLICE MEMBER #6
'04Liberty--3.7L, auto, 4x4
Joe
Posted 20 August 2006 - 05:24 PM
I prefer to completely disable my jeep from being driven.
I don't have pics or a writeup sice I did it many years ago, but i'll explane it to you.
Find the fuse for your fuel pump, cut it and install a toggle switch in line.
hid the toggle somewhere in your jeep, when you get out, flip the switch.
If someone tries to hotwire the jeep, she will start and run for 15 seconds till she runs out of gas that was in her line, then the motor dies and sounds like there is an engine problem. no theif will stick around to figure out why its not running.
just remember to flip the toggle before you start it, there have been many times that I'm backing out of my garage and it shuts down, takes me a second to remember why.
This is the best way to disable your jeep from theft, so good, you can leave your keys in the jeep when you aren't around.
Excuses are the tools of the incompetent
..CISCO..
Posted 21 August 2006 - 06:27 AM
I did something similar. Should work great
'98 Grand Cherokee
Ru•bi•con n.
Posted 29 September 2006 - 10:32 AM
black 94 yj, 2.5L 2.5" shackle, 31x10.50 bfg m/t, baja lights
http://www.myjeepspace.com/yjcrazy
Posted 29 September 2006 - 06:47 PM
Wildbill
Port Charlotte, FL
1992 YJ 4.0 HO
Aussie Lockers Frt & Rear
33 x 12.50 Dunlop Mud Rovers
2004 Liberty Sport 3.7L 4X4
stock for now!!!
Posted 04 October 2006 - 08:39 AM
Posted 05 October 2006 - 09:23 PM
JBUGGY, on Oct 4 2006, 09:39 AM, said:
Oh!!!!
Thanks......... I think
Wildbill
Port Charlotte, FL
1992 YJ 4.0 HO
stock for now!!!
