Jim, did you notice the suicide doors on CJ5's Jeep? This looks like a home-made top.
Suicide Doors CJ5
Posted 17 January 2006 - 11:29 PM
Posted 18 January 2006 - 12:53 AM
Good eye Jack, nice to see somebody notices the details.
No, it isn't a home made top, though I did spin the hinges around myself.
I thought it would be easier to climb onto the hood when I was stuck in the mud.
That top is actually a factory made top from a 1975 or older. Notice the angle of the windshield....WAAAAY too straight up and down to be a '76 or newer.
Jim, I'lll be takng the 5 for a boot tomorrow. It has been so cold that I have been drivin the Rubicon almost every day, but it is supposed to be warm so I'll get that pic for you then.
Real Jeeps are BUILT ! All others are for haulin groceries and babies...
Posted 18 January 2006 - 04:36 PM
Thats a cool idea. How much trouble was it to reverse the hinges and latch?
Posted 18 January 2006 - 06:52 PM
Well, I had to make all the hardware..... I have to say that I am a fairly experienced fabber, and in saying that, It was enough agrivation that I'd probably not do it again. Believe me, It was 20-25 hours of labour to make it work, and even now, I want to tweek it a little....
I also put hinges in between the body and front fenders, so that I can open them up for easier engine maintainence.......
Posted 18 January 2006 - 09:05 PM
Hum, I don't see a 4x4Rescue.org sticker on that Jeep. :sneak:
Posted 19 January 2006 - 12:12 AM
If you send me 2 sets, I'll put them on both of my jeeps......
#7 Guest_Mongo_*
Posted 19 January 2006 - 09:43 AM
You guys should be ashamed!!!!!!!
I got that exact same top a few weeks ago and now I am going to want to change the door hinges on top of everything else I have to do to it
Posted 19 January 2006 - 10:31 AM
Take lots of pics......
The most agrivating part of this restoration was having to cut the oval hole in the body (after painting) for the TJ filler spout and cap.
#9 Guest_Mongo_*
Posted 19 January 2006 - 12:22 PM
I won't have that problem since I'm not doing that mod :D
I have enough to deal with the brakes, power steering, on boar air, wiring, and 50 other things
