My biggest problem with my Jeep was that the seats sat to low....I found this on eBay, and now the problem is gone....can see clearly over the Hood.....
if any one wants these let me know...they cost about $50 bucks. oh they are paint-able...when I go do my spray on liner, I will have them incorporate it into the tub...
JeepDew
Seat risers
Posted 08 January 2006 - 05:58 PM
I own 2 Jeeps, both of them
04TJ & 88MJ
04TJ & 88MJ
Posted 08 January 2006 - 07:59 PM
Plastic or metal? If plastic, there would be a safety concern if in a serious accident. Is there a warning put out with them or does it say the product is intended for this application.
Just curious,
Just curious,
Posted 08 January 2006 - 08:23 PM
R U heighth challenged? Just like I'm word challenged! LOL
85 CJ7 258/T5/ AMC20/Dana30, 38mm Weber/ 132K miles - 33" 12.5's Pro Comp MT's, one piece axles, Detroit Softlocker rear, Lock Rite front, Warn Hubs, 4.56 R&P, 4" BDS lift w/ - brake hoses, Warn x8000i, Warn winch guard, Hi-Lift, high back seats, Tuffy console, Breezer bikinni top, Four X Dr. rocker guards, Rock Hard sport cage, Kilby OBA with 1.75 gal tank and York 10.3cc compressor. Working on my 4.0 conversion now.
Posted 08 January 2006 - 08:30 PM
Just curious,
Just curious,
solid polymer, he makes them for this purpose.....why would it be a factor if there was an accident....grade 8 bolts and solid foundation......
04TJ & 88MJ
04TJ & 88MJ
Posted 08 January 2006 - 09:28 PM
Just curious,
Just curious,
Just wondering if the plastic split & then the seat became loose thus ripping the bolts out through the floor, with the seat coming loose it would give more leverage with the weight (you) on the seat. Hummm.
Is it DOT regulated/approved?
Just asking cause my wife is vertically challenged, :sneak:
Posted 08 January 2006 - 09:38 PM
There is now way that this polymer will break, torqued it down to 50lbs, and risers did not even budge.
hope that helps, it did for me, now I can see the low riders when i go over them..... :sneak:
04TJ & 88MJ
04TJ & 88MJ
Posted 09 January 2006 - 01:10 PM
Latest 4WD Hardware Catalog has seat risers also and they look metal and I believe about the same price
Wildbill
Wildbill
Yale H.
Port Charlotte, FL
1992 YJ 4.0 HO
Aussie Lockers Frt & Rear
33 x 12.50 Dunlop Mud Rovers
2004 Liberty Sport 3.7L 4X4
stock for now!!!
Port Charlotte, FL
1992 YJ 4.0 HO
stock for now!!!
