CJ8 to M170 Conversion
#61
Posted 18 January 2009 - 07:46 PM
Now a modern set should be able to be converted to 12 volt with turn signals fairly easily. I'd personally put yellow bulbs in the driving lights (the small ones with the long rectangular clear lenses and the small triangles insides where the lights shine through. They'd probably make decent turn signals.
The Mighty Mite has only one stop light and no turn signals. I believe modern 24 volt lights have better push button controls for the lighting and might be easier to convert to turn signals/dual brake lights. Have you looked into the HMMVW rear lights or do you want to keep that fake/authentic M170 style?
#62
Posted 18 January 2009 - 10:06 PM
SoilantGreen, on Jan 18 2009, 07:46 PM, said:
Thank you I will check on it.
Interesting, sounds like a plan
Now Dave, I have to keep up w/the theme or the boyz will shoot me after going through all this.
#63
Posted 19 January 2009 - 06:49 AM
As far a legalities, I believe that you ave to have turn signals if it came with it from the factory. It amy be a replica of a M170, btu if/when you get pulled over by the police, they could have issues w/ no signals. (I know, even the cops don't use signals)
#64
Posted 19 January 2009 - 10:12 AM
P.S. Dave, I haven't found Tom D yet but a guy who helped him, he hasn't replied so I'm not sure if he knows how or not.
P.S.S. DAVE, in reference to the tail/rear light hook up. The factory military lights have the screw plug to hook them up, I do not have any & would like to splice them into the CJ's harness @ the light its self so I can just switch connections. Do U know where I can get some (I know Midwest military) locally, maybe off your shelf
OOps-after further review I'm not sure I an do that Dave.
Here is a picture of the front/rear lights & there connectors. Am I better off gutting the wiring, I was thinking of splicing but w/the one wire I don't think it will happen. I'm trying to remember, I think the center electrode is the current & there is shielding around it for a ground etc. unless the Jeep body is the ground.
With no turn etc. all they needed was one electrode. I just hate hacking up NOS products.
#65
Posted 19 January 2009 - 11:00 AM
On single filament lights, the center contact is power. On dual element bulbs, there are 2 power contacts in the bottom of the socket, 1 for taillight, and one for the signal/brake light.
Remember, the dual filament bulbs have 2 lugs on the sides that are different distances fromthe base of the bulb. The single filament has 2 lugs at the same distane from teh base of the bulb.
What may be easier to adapt is the new spade type bulbs that do not ahve the metal base around the bulb.
As you know, if you go to LED, you have to get a resisitor in the system so the signals will not flash at a high rate of speed.
#66
Posted 19 January 2009 - 11:23 AM
That being said, you're welcome to whatever I have left from the Mite's old 24V stuff. There's a couple of different sizes of waterproof male and female connectors, so it may not help as much as you're hoping.
#67
Posted 19 January 2009 - 10:34 PM
Thank you Ian & I did forget about the resistor.
Dave, if you think it can help (I could use the water proof boots where they connect) cause I have to do the front as well, it really STINKS, these are excellent built lights. Trying to keep true the the FAKE/Authentic build
PM me & we will figure out something, I will not need them for about three weeks when I put the tub on.
Thanks again guy's.
#68
Posted 21 January 2009 - 06:07 PM
#69
Posted 22 January 2009 - 08:15 AM
I know you already did the bending but is there any way you can route the line up and not following the tube
Not sure where you would take the vehicle off road but if you back up into a tree, rock, etc you might just dent, pinch or take out the line. I had to weld a square small half channel to the axle tube to protect mine as I had no other way to go up. I actually took one out a few years back.
Now that you have the tub off (if the gas tank does not get in the way) see if you can go up and follow the cross member support over to the other side.
#70
Posted 22 January 2009 - 11:04 AM
If I were to go up and over I would have to use rubber from the top center as seen in pic #3. I'll see what I can do, I'm on a very limited budget (no work) & installing the items I have previously purchased. That is another reason I had to SUA the Jeep, DS costs etc. SodMan has a front DS for an auto he is donating to the project & I have the rear out of the J-10 I am going to grind the yoke weld off & shorten as well, I guess U will want a write up on that to . I'll look into it, thanks.
P.S. Those who would like to donate to the project VIA parts or $ will get there name on the inside of the bed as a memorial As for U SodMan- I will just grow some grass in the back , no WildBill, yard grass
#71
Posted 22 January 2009 - 02:45 PM
Here are some pics of the underside of the CJ8 tub. Getting ready to clean/prime/paint.
Rear:
Middle:
Front:
Whole tub:
#72
Posted 23 January 2009 - 02:23 PM
Tub rusted areas sprayed w/Metal ready. Now, the directions do not say, but do you rinse the M-ready off. I don't think so.
#73
Posted 23 January 2009 - 08:31 PM
#74
Posted 23 January 2009 - 09:30 PM
#75
Posted 23 January 2009 - 10:03 PM
The blue is painters tape over the bolt holes for the body. I didn't have enough for the wheel wells and back up in where the tail lights go but I can always do it later, easy to get to. I still have some rust I need to clean up and do on the inside so I might have to get a pint of the stuff or just shoot it w/R-Oxide or something more modern.
#76
Posted 24 January 2009 - 03:00 PM
Enhanced version:
Taping the holes two days after the Por-15 & paint job. Yes, those couple of holes in the floor pan are for historical purposes
#77
Posted 24 January 2009 - 09:27 PM
I took out the filler cause I was looking @ options as far as mounting the military lights. As you can see, there is plenty of room if the filler is moved to the side of the Jeep. Now, if I don't move it, the light on the filler side will not work (veryyyyy tight, maybe, doubt it) unless I mount it outside & just through bolted it (look like ) to the tub, it would stick out just as far as the stock (oh, no) square tail lights.
Below are some pics of my meaning.
Don't rag me about the paint job, remember what Dave said.
Now, it will fit up in there a little more, the plastic housing is holding it back.
The gas lines run through this hole. Also, look @ the fillers metal, where it mounts to the plastic it is ROUND . I could get rid of the plastic housing & just hole saw the outside & mount it using an old style cap. Second thought, just hit me this second, if it is there & I hit some trees etc. .......... Maybe to much to worry about.
Showing the metal rib on the right of the plastic housing.
See, there is room up in the triangle section.
#78
Posted 27 January 2009 - 08:52 PM
Twin stick brackets-fit like a glove.
Note: All OD will be touched up @ final inspection. Still using up those rattle cans.
#79
Posted 28 January 2009 - 01:59 AM
#80
Posted 28 January 2009 - 09:49 AM
#81
Posted 28 January 2009 - 10:18 AM
Rollbar, on Jan 28 2009, 09:49 AM, said:
you want to run your rear tub wiring harness before you put the tub on, if at all possible. you never know how big your fingers are until you try to fit them in those spots after the tub is on the frame.
#82
Posted 28 January 2009 - 11:09 AM
#83
Posted 28 January 2009 - 12:01 PM
I think it might be best when the tub is on & the battery hooked up, then I can get some bulbs out of stock and try the wiring etc.
Did U read my post in POST #77?
#84
Posted 28 January 2009 - 03:52 PM
So, for about 30 bucks I have twin stick (the shifter was 15 bucks), but that was three years ago, might be cheaper now due to the economy.
Twin Stick Post
Mock up of the sticks.
#85
Posted 28 January 2009 - 09:24 PM
looks good, can not wait to see it done in 2059. thats my b-day i will be 100.
we must have a drink when my willys is done.
#86
Posted 28 January 2009 - 10:01 PM
We will C.
Yes, I have gotten some what wiser
#87
Posted 02 February 2009 - 05:32 PM
Here's where it is 1 3/4" away @ the closest point.
#88
Posted 02 February 2009 - 10:28 PM
#89
Posted 03 February 2009 - 06:32 PM
#90
Posted 07 March 2009 - 04:59 PM
Sender
Top of tank-vents
Tank prepped/cleaned & painted w/Red Oxide
Tank painted w/23070 OD
Tank installed
