CJ8 to M170 Conversion
#31
Posted 01 February 2006 - 08:46 AM
You are really going all out.
#32
Posted 06 February 2006 - 04:03 PM
Having fun spending $
#33
Posted 07 February 2006 - 07:24 PM
Getting there,
P.S. All the other stuff (NOS parts, lights etc.) are in transit, I'll post pics when the stuff gets in.
#34
Posted 08 February 2006 - 08:01 PM
Pics below:
#35
Posted 08 February 2006 - 09:26 PM
Tally up fellow Jeeper
Btw, we will be making raids with our vehicles, I'll tell you what kind later.
#36
Posted 08 February 2006 - 10:17 PM
P.S. All lights are 24Volt. The NOS shovel bracket is dated 1953.
#37
Posted 10 March 2006 - 06:27 PM
Now I can realiy go underwater. For those of U who have K&N, j/k.
P.S. I have to find or make a air filter for it now. Any ideas?
Here is the sellers comments:
This is a very nice and straight M38A1 air cleaner. There are no dents and the paint appears to be pretty good. It needs to be cleaned off though. This one comes with all the parts you see attached to it in the pictures. The inside looks new. These are commonly missing from M38A1s but if you looking, I guess you know that.
I have a bunch of other M38 and M38A1 stuff up for auction, I'm cleaning out my parts collection since I just picked up a new toy and need the room.
#38
Posted 11 March 2006 - 10:10 AM
You can actually run a straight hose into it but if your really going to take that M170 that deep do a search on JeepTalk for snorkels and see if you can adapt one of the smaller setups inside that housing and just attach the hose to it.
#39
Posted 11 March 2006 - 07:00 PM
Here is a good write up on oil bath filters.
Oil Bath Air Filters
Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
How it works
When the engine starts, it sucks a certain amount of the oil out of the cup allowing it to coat the packed-in metal "shavings". This packing causes a massive increase in the amount of oil soaked surface area available to stop dirt particles. The cannister is designed to be the correct height to allow the proper weight oil to not be sucked into the engine but only pulled to the top of the can.
Uncleaned air is sucked in by the same vacuum that draws the oil up on the "shavings". The air is drawn downward towards the oil sump at the bottom of the cannister, usually through a center pipe. Any particles that are truly "large" will likely continue down into the oil left at the bottom of the cup and be trapped. The small dirt particles are trapped on the oil soaked "shavings" as the air moves upward through the outer cannister. If the correct weight oil is in the cup, the end result is that the air leaves the top of the cannister clean.
Potential Problems
The first problem comes with using the wrong weight oil. Use of oil that is too light will cause the oil to be drawn beyond the filter and into the engine. Use of oil that is too heavy will not allow the oil to be drawn up far enough and much of the air cleaning surface area ends up being unused. Manufacturer owner manuals always show the oil weight that is designed for the system. Engineering of the system (we hope) will have picked just the right weight for the size of the cannister, cup, and vacuum pressure.
The second problem comes when the cup is not cleaned regularly. Manuals always recommend daily refilling of the cup and suggest even more frequent cleanings under dusty conditions. The oil may look clean in the cup but after a few hours of running but it has trapped a significant quantity of small particles many of which will be drawn back up into the cleaning surfaces. When the particles-to-oil ratio reaches a certain level, the dirt will begin to hang on (or "sludge up") on the cleaning surfaces. Eventually, instead of just clean air being sucked into the intake, you have chunks of dirt and sludge going with it. Obviously this can be quickly damaging to the engine. If your cannister is filled with sludge, clean it out before using it or it could do more harm than good.
The last problem is with radically altered machines. The oil bath is engineered for the stock engine. Radical changes to the engine mandate changes to the air cleaning system. Care should also be exercised if replacing your oil bath filter. The replacement should be similar in size and engineered capacity to the original.
#40
Posted 12 March 2006 - 07:03 PM
Because of this you've made me look back at my manual to see what they recommend for oil weight as I run an original oil bath air cleaner.
I have looked into my intake and it does look mighty clean. I've changed engine oil but I never have opened the oil bath unit since the engine only has 1500 miles from when it was all redone.
#41
Posted 13 March 2006 - 10:49 PM
P.S. I just ordered my gas tank filler lines from 4WDH, another 70 bucks but I have to have'em b-4 I mount the tub, I want to get everything done I can b-4 the tub goes on. The PO cut the filler lines & the CJ7's won't fit, to short.
P.S.S. This weekend I hope to finish the steering mount (had to drill & tap some holes last week ) & mount the tub. We will see.
#42
Posted 27 March 2006 - 08:07 PM
I used the rear of the stock shackle & I cut the old front CJ ones off to make a spacer so I didn't have to grind off the rivet.
Now I did buy a pair fromJCW for the rear that were gusseted (if that is a word) but they are allot thinner metal & cheap. So use the rear up front & buy or get a set for the rear.
I have pics but I am working on my NEW album from my NEW host so I will have to post them here later.
Hopefully I can get the tub on next weekend (trying to get moved) so I can move my project to my NEW warehouse which will be for my NEW site etc.
P.S. It steers,
O.K. here's some pics, paint still kind of wet & it looks like I missed a couples of spots but that's O.K. I'll catch it later.
#43
Posted 30 December 2006 - 08:22 PM
I bought it to cut it up & use for filler pieces on the 8 so I'm not worried about the door seat, I just wanted to point it out to those who might purchase one. I did over lay it on the body & it is very close.
P.S. Notice where it was made, . At least it wasn't made in China,
#44
Posted 01 January 2009 - 06:07 PM
look where they R made. Tranny Doc should like that
We will be building a set of rock guards later on w/a step. Oh, did I mention, adding the body to this measurement would make the top of the rear of the Jeep 5' off the ground plus a 1"BL. It should setting some, I hope. There is a 12" load spring to help when I tow the camper. I hope it doesn't crack the spring where the load spring ends, still contemplating whether or not to leave it due to that reason.
Oh no, I just realized I didn't prime the shocks & then OD them. Jim is gonna have my tuercas.
#45
Posted 02 January 2009 - 11:11 AM
So here is what I have (w/out the cups but it's very close, I guess I could put them in but this is just preliminary). 14-15* on the stock set up. The pinion is almost parallel to the t-case & the DS is almost fully collapsed. (looking for a flywheel for a 360 so I can mount my T-176 back in, donations excepted )
Drive shaft measurments-yoke to yoke-cup to cup are:
Front - 35 1/8"
Rear - 32 3/4" - 32 7/8" trans must be off a hair.
Can't find my dial indicator :(
I do have a 1" T-case drop kit in stock.
I also have some 6* shims.
Maybe I should just go w/the 2.5 SUA & the 1"BL. :(
#46
Posted 03 January 2009 - 11:42 AM
I'm glad to see that you picked up and are continuing this project. Get it ready for when you have to leave it at my place.
With regards to the DS....
First, please do not use the TC drop, it looks like hell and you are defeating the purpose for ground clearance. Take the J10 DS CV that you have which is too short, send it to Tom Wood. He will lengthen and rebuild whatever is screwed up. It will not cost as much as a new one (only a fraction).
When you get it, set it .5 to 1 degree below the pinion. Under torque she will be at 0 degree.
#47
Posted 03 January 2009 - 11:46 PM
#48
Posted 04 January 2009 - 10:45 AM
Rollbar, on Jan 3 2009, 11:46 PM, said:
P.S. My $3.99 angle/degree finder will be here shortly from HF.
That is all I have is the cheaper angle finder which I got at Sears and it will works just as good.
What I meant was the have the rear diff angle .5 to 1 degree below the DS in parallel.
#49
Posted 04 January 2009 - 03:04 PM
Now, does this apply to SOA since the rear would rotate more?
#50
Posted 05 January 2009 - 08:46 AM
#51
Posted 10 January 2009 - 07:40 PM
Here's the old man tightening down a shock.
More to come.
Just a note: had to re-convert to a the SUA (picks when the camera gets new batteries), the War Dept's troops said it was to tall. Oh well, at least everything will go back easier. When my dial indicator comes in I will check the outers for the degree that they are setting & if need be add shims to obtain 4-6* of castor with 6* being the optimum.
P.S. I have a pretty good color scheme coming up for the axles that might look good. I have to paint them before the tub goes on. What do you think about this.
1. Outers=Black
2. Tubes=OD
3. Pumpkin=Black
4. Steering=OD
5. DS=Black
#52
Posted 11 January 2009 - 08:42 AM
On your color scheme. Paint everything OD except for the outers drums. When you need to touch up a few things it would be much easier and it would look too bling. Besides there never was any color schemes in the military. They would OD everything including your butt if they needed to.
Take care of the M170 for me and let me know when she is done so I can bring the trailer and pick her up.
#53
Posted 11 January 2009 - 03:04 PM
Thanks Jim, if I do go to NZ (still in the planning stage for 2010) then I will drop it off completed (probably have to get rid of all my Jeeps/STUFF :( ). I measured the height of the total finish and the top of the 8's rear bed would have been @ 5 feet w/the 2.5" SOA. I'm not getting any younger so the kids twisting my arm said that it would be better off lowered. So the plan still stands w/the 2.5" seen below & the 1" Day-star BL I have in stock. I think it will be plenty high for me & I can go most places in the South East. It did cut down on expense & build time. I just wish I could come up w/a Flywheel for the 360 so I could mount my clutch, then my DS would not have to be shortened on one end & lengthen on the front. If I do do it, I'll do a write up on it. Since I bought the kit a year ago I might as well replace the seals on the D-300 since it started to leak. Easier to do it now.
So, here are some pics of the 2.5" frame only w/yJ shackles & 6* shims under the rear axle (I do have the big long ones but...........).
Next, brake lines paint then the D-300 re-seal, gear swap, DS & get rid of those shinny V-covers & put the stock one on painted black.
#54
Posted 12 January 2009 - 08:14 AM
I say if the axle housing is already painted black along with cover leave it all black and it does look good. I would not mix OD and black though. The 2.5 looks good but if you get a chance on a rainy day turn those white walls to the inside.
#55
Posted 12 January 2009 - 10:03 AM
Thanks, I figure after I do my first gear install ( ) on the rears I will paint them. Nice thought on the tires, I do have someone who mentioned they have free CJ original white spoke rims I could OD .
#56
Posted 12 January 2009 - 10:26 PM
Remove shifter and shift plate for twin stick
Remove D-300
D-300 on the cooler
Rear of T176-clean
Removing front yoke nut
Removing yoke w/my steering wheel puller-sorry, all I had
See, I told you it would work, slid right off
Front seal leaking
Remove pan to drain it quicker
Funky stuff, looks like it may of had condensation or some H20 in it
Not any more
Shift rail holder & bolt
Removing aluminum housing to replace seals
Blue loc-tight on shift rail bolt
Aluminum housing re-attached & sealed
Super 300 on the housing where the seal is going to prevent leaks
More super 300
Super 300 on the outside edge of the shift rail seal
Tap shift rail seal in w/a piece of conduit (thick wall), make sure U hold it straight, I cocked the seal but drove it home
Super 300 on front yoke seal & aluminum housing
Grease the front yoke seal rubber & the outside with super 300
Remove & clean front yoke rear bearing cover & shims
Put super 300 on the T-case then install one shim & more super 300, then the last shim & super 300 on the cover.
NOTE: Do not use RTV, it might set the tolerance off on the shims.
Clean bolt threads & dab some blue loc-tight & install cover
Install T-case back on T176-put grease on the output seal of the tranny.
RE-install in the reverse order and follow the torque spec & you are good to go. Sorry, didn't have time to document it.
#57
Posted 16 January 2009 - 02:43 PM
The fluid came out a little rusty but clean.
BTW-it cleaned up well, thanks Ian.
I painted the plate w/Galvanized primer then flat black & then OD green.
#58
Posted 18 January 2009 - 12:06 AM
With the rear & front lights (stop etc. Won't have a turn signal w/these ???) will I be able to run them on my build since they are not factory or do they need to be a certain lumen/visual size from a distance. I never thought of it when I bought the NOS parts. I just don't want to drill a hole in the bed (Oh, it pains me to even think about it due to the rarity of the CJ8) to install these if I can't use them.
I did remember someone on here using these lights and adding a LED or something to them. I would like to see the write up to convert but I would also like to keep the original bulb set up to 12V but it might not be bright enough.
Now, the rear will be stop, not sure about turn (haven't looked into it), maybe Jim can see if his are turn equipped when he puts his signal on, I just can't remember that far back.
Pics below:
Here is one of the rear lights opened up, nice rubber mounting, eh!
#59
Posted 18 January 2009 - 08:38 AM
Jim,
I can only tell you how mine work which is only ON (driving lights) & Stop. Mine is a housing and the bulb is actually a whole assembly that plugs in. By the picture you posted your housing looks the same on the outside but different on the inside. Not sure if I can confirm on yours if you will have a turn signal. I use hand signals when I'm driving.
Before you cut, can you just hook them up to the wiring to see how they work Call up the outfit you bought them from and see what they say. They might have improved over the years to the M170 and put the turn in. Let us know.
#60
Posted 18 January 2009 - 02:17 PM
Jim, someone posted & used these lights but installed the LED's, I can't find the post but it was on a red Jeep I think & not yours.
