CJ8 to M170 Conversion
#181
Posted 29 October 2011 - 04:34 PM
#182
Posted 31 October 2011 - 07:13 AM
The fuel gauge, is it working? Key on pic there is no movement, you have to have gas in it.
#183
Posted 31 October 2011 - 03:22 PM
Jim B, on 31 October 2011 - 07:13 AM, said:
I did put some of this in w/carbon fiber, ONLY because $$ is tight etc. So far it is working 97% but I haven't driven it yet to really get it hot, just idle/1200rpm like the directions read. Just a small leak but I'm going to go out and change the oil and let it run.
I hate to use stuff like this but at this point I had to. If it does not work, then I just might pull the whole motor and save some $ and re-build it.
http://www.barsproducts.com/HG1.htm
Someone did post this, check this product out.
http://www.rxauto.co...CFQ0CQAodwiMzSA
Yes the gauge is working, I put 3.5 gallons in it and the gauge came up to the top of the "E" at least I know when it gets to the top of the "E" I have 3 gallons and not like most CJ's where the gauge is way off. Peaches gauge use to read 1/2 tank = empty, now after the new sender install I could only get it down to 1/4 = empty. So I'm happy to see the gauge reading very close to empty.
#184
Posted 31 October 2011 - 10:06 PM
#185
Posted 31 October 2011 - 10:58 PM
#186
Posted 01 November 2011 - 06:53 PM
#187
Posted 04 November 2011 - 06:31 PM
Ran well, still some tweaking and finishing up work to do, but its coming along.
I would like to take this time to thank EVERYONE who helped and answered my questions during the building process.
Thanks again,
Jim
P.S. More pics to come for the completion-stay tuned.
#189
Posted 18 November 2011 - 02:50 PM
Still not 100% complete, but getting there.
The wife said when I got the Jeep on the road she was going to get these plates for me as a gift.
#190
Posted 23 November 2011 - 12:42 PM
I like the Rollbar tag, nice touch. Btw, if you play your cards correct you might not have to display it.
#191
Posted 23 November 2011 - 02:01 PM
#192
Posted 26 November 2011 - 03:11 PM
Stock CJ8 Bracket
Had to cut/round the stock bracket to fit the rim as well as bend in and blend in a rounded edge for the inner rim
New extension bracket mounted to the CJ8 stock bracket. Note: we counter sunk the holes for the stock bracket stud welds
Bead blasted the metal then painted w/black paint
Mounted bracket on the roll bar
Need to paint the rim black
#193
Posted 26 November 2011 - 08:13 PM
#194
Posted 05 December 2011 - 04:13 PM
Question is, do you like the black rim (camo now but will b black), or the aluminum rim?
OR,
Maybe paint the Alum rim w/green in the circles Hum.
P.S. I still have to build my rock guards and paint the doors.
#195
Posted 15 December 2011 - 08:03 AM
I personally like the black on the rims, other black trim will make good contrast rather than all in OD since you did not go M170 all the way. It is looking sweet, your going to have to do something with the door though.
#196
Posted 15 December 2011 - 04:23 PM
RuggedRidge XHD Bumper with stinger
Recon 10,500 lb Waterproof Winch
TeraFlex 2.5" Coil lift + Spacer Leveling Kit = More lift than I bargained for...
Smittybilt SRC Side Armor
KC SlimLite 130W on KC windshield brackets
35" Fierce Attitude M/T
Wish List
Snorkel
On Board Air
Front Fog Lights
Lockers
#197
Posted 15 December 2011 - 04:28 PM
Wish List
Snorkel
On Board Air
Front Fog Lights
Lockers
#198
Posted 15 December 2011 - 08:21 PM
Now the question: on Peaches Jeep she has steel rims/chrome and I was thinking of painting them but not sure if the paint will stick.
ALSO, I can etch the aluminum rim and paint them black and the INNER circles paint OD green as a contrast.
Thought?
P.S. I am still leaning to the M-170 stickers (but buying the paintable templates). I will put my dads military info on the bumpers/side of hood in black to keep the colors coordination going. I did find some FULL lenses for the original military brake lights
Getting there.
Just dropped the tank and installed a new sender, even after adjustment 1/2 tank reads almost 3/4. NEVER trust a Jeep gauge.
#199
Posted 27 December 2011 - 10:03 AM
Thought?
I've seen applications in where paint can adhere to chrome and aluminum, I personally don't have any experience with this. I have however seen how the paint starts to peel off after a while and it looks like crap.
Man this is a must and I would really like to see you do this.
#200
Posted 27 December 2011 - 03:12 PM
OK, doors painted and the color needs to fad a little to match the tub. Still wet.
I will put the military info on the Jeep (division/company etc) in black and w/the contrast of the OD it should look pretty good.
Don't mind the flash.
And yes I will do the Black letters on the OD. I have to look to see if the lenses from MidWest Military will fit the 6 bolt pattern of the lights I have now. They should as they are made to look NOS for the street driven Military Jeeps. $24.00 each.
#201
Posted 03 February 2012 - 08:41 PM
#202
Posted 03 February 2012 - 11:16 PM
#203
Posted 06 February 2012 - 07:46 AM
What no pic of the inside with a quarter so we can tell how much room
#204
Posted 06 February 2012 - 03:59 PM
Passenger side:
Drives side:
Bed shot:
#205
Posted 07 February 2012 - 05:07 PM
#206
Posted 02 July 2013 - 02:40 AM
Hayden set up from Summit
