CJ8 to M170 Conversion
#151
Posted 29 January 2011 - 10:28 PM
Stock tunnel plate
Raw metal for tunnel plate
Tracing out stock tunnel plate
Getting ready to cut the metal stock
Grinding the edges of the new tunnel
Edges ground
Holes drilled in plate
Trace for twin stick cut out
Every thing smoothed out and painted, shifter in position (temp) to be bolted down
Shifter bolted down
Shifter cover installed, need to cut the housing so it sits flush on tub
Shifter bracket installed on tranny
Once the build is complete ever thing will be cleaned up.
#152
Posted 09 February 2011 - 08:15 PM
Maybe I also need to check where it plugs into the harness, I should have 12v to ground @ the plug by the tank, correct
#153
Posted 09 February 2011 - 08:55 PM
#154
Posted 10 February 2011 - 10:33 PM
NAPA Part Number for '74, AMC-360V8
Engine Block Heater Components
Used RTV
Freeze plug location, passenger side, rear
Remove starter
Freeze plug behind starter
[imghttp://www.street2mud.com/albums/M170Start/100_2994.sized.jpg[/img]
Starter removed, not sure what the hole is, maybe casting.
Starting to remove freeze plug
Used vise-grip needle nose pliers to work out the plug
Freeze plug removed
Clean out block
RTV on rubber gasket of heater
Block heater installed
Block heater cord installed and RTV added for sealant
Wire loom being installed on heater cord and cord routing
#155
Posted 11 February 2011 - 01:58 AM
#156
Posted 11 February 2011 - 12:24 PM
Is the overflow NOS
#157
Posted 11 February 2011 - 12:35 PM
#158
Posted 14 February 2011 - 08:42 AM
#159
Posted 14 February 2011 - 11:28 AM
Cranked it the other day but my Edelbrock intake is leaking Rad fluid and the rear bowl of the 600cfm carb is pouring into the secondaries so I'm just going to rebuilds the carb while I have it off.
#160
Posted 15 February 2011 - 07:18 PM
#161
Posted 12 March 2011 - 01:29 AM
Removing the intake
Intake gasket installed by previous owner
Starting to remove the intake gasket
Intake removed and flipped for cleaning, notice anything, no RTV etc
Getting ready to clean the block etc
Cleaned block not ready to scrape off where the intake goes
Block cleaned
Intake cleaned
Intake installed
The rubber gasket kept bulging out so I just used RTV after two complete tries. The rear one worked and I did trim them per the directions.
Look what came out of the intake when I flipped it
#162
Posted 14 March 2011 - 09:17 AM
Did you have any problems in getting the parts
Is that black beans and rice after digestion that came out of the intake.
#163
Posted 14 March 2011 - 10:54 AM
Installed the carb but the fuel rail was leaking so I think I fixed it and will complete it this week, then firing it up again.
#164
Posted 23 March 2011 - 10:46 AM
Ok, here is the video.
Oil Pressure:
60psi = cold
45psi = warm
24psi = hot
Still have to get the temp gauge & fuel gauge working.
Thank you all for your help.
My U-Tube video of her fired up:
#165
Posted 23 March 2011 - 06:32 PM
#166
Posted 24 March 2011 - 03:50 PM
1987 YJ7TJ
That's all folks!
#167
Posted 25 March 2011 - 07:18 AM
BTW what gauge steel did you use for the hump cover? I need to do the same this week.
#168
Posted 25 March 2011 - 11:36 AM
One thing, make sure you shape it then draw the cut lines to fit or it will be short.
#169
Posted 25 March 2011 - 05:14 PM
Exhaust routing planning:
#170
Posted 26 March 2011 - 06:42 AM
#171
Posted 22 April 2011 - 11:56 PM
Mechanical temp gauge
I couldn't use the radiator neck so I had to use the intake port for the mechanical gauge.
Mechanical oil gauge
Volt meter
Sorry for the blurred pics, weird day w/the light.
#172
Posted 23 April 2011 - 05:54 AM
#173
Posted 01 October 2011 - 03:21 PM
Bought some dumps 2-1/4" so when I want to be loud I can
Installed steering wheel and painted seat brackets and re-installed.
Adjusted the passenger door and waiting for the drivers side door striker to come in along w/the factory knobs for the twin stick.
Painted the 1/2 hard top and installed.
Installed the seat belts but I need two seat belt extensions 12-18" due to the CJ8 set up and connecting to the roll bar.
Installed NOS side mirror and I want to powder coat the side mirrors arm black.
Installed air filter system.
I still have to do the door side panels, rock guards, touch up and paint the doors as well as clean up the inside. Still little things to do.
Also need to bleed brakes, install NOS review mirror, check fuel sending gauge in tank w/a spare I have to see if the gauge registers.
I am taking the exhaust to a guy in town to do. I bought all the stuff and returned it because he can do it for the same price and probably better.
So in the mean time I did drive it around the property here and washed it
#174
Posted 10 October 2011 - 05:20 PM
Transmission looks excellent and I did have to drop the valve body.
Refilled tranny pan etc and now she shifts great and no leaks.
Next Monday the exhaust will be completed
Then tags, then ON THE ROAD!
After that I'll finish up the small stuff, cosmetic.
#175
Posted 14 October 2011 - 08:47 PM
I could just buy a fuel gauge but I would like to fix this one. I have read all I can about the fix but I'm either stumped or just need to walk away from it for now.
NOTE: I checked the fuel sender again and I still can't get it to work. Read below.
1. Still No juice and fuse is good.
2. Have power to Fuel gauge but they both don't work.
3. Did the ground to sender w/Key on to see if the gauge moved, it didn't.
4. Question:
Does some one have a GOOD picture of the dash wiring so I can check mine against it just to make sure.
BTW-I installed manual oil/temp/voltmeter gauge in the dash. But would still like to get the fuel working, if not, then I'll buy one and I guess use the power lead to the original fuel gauge.
5. OK, After checking everything SEEMS like I have NO juice @ the fuse. I pulled the fuse to check the block and NO JUICE on the prongs.
6. Question:
Does this mean when I plugged it in they may have missed?
Or ?
7. I do after checking (w/the key on) have power to the red wire going to the gauge. Hope it didn't fry it.
Here is an old pic of my dash wiring:
8. OK, Checked Peaches (1986 CJ7) Jeep and the ACC.LPS (3amp fuse) does not have juice w/a test light and key in the on position. W/key on, the red wire going to her fuel gauge is hot....... SAME AS MINE.
9. I noted that she has a Purple wire w/a orange stripe going to her temp gauge whereas MINE has a purple wire w/a white stripe (1984 CJ8).
10. I'll check tomorrow and see if I have a purple wire w/a orange stripe for the temp.
11. What I can't figure out is why w/the Key one the ACC.LPS on both Jeeps w/the fuse removed has no power.
12. Also, I did pull the wire apart @ the tank and no power w/a test light @ the plug in going to the tank.
#176
Posted 19 October 2011 - 05:52 PM
#178
Posted 21 October 2011 - 07:35 AM
What about turning the clamps to the side just in case you hit the grass.
#179
Posted 21 October 2011 - 11:46 PM
Na, we do have some around the house etc. But you are right, I need to move the clamps and get a different one for the front.
The mufflers are supposed to be quiet flow but flow well and that is why I have my dumps installed so I can open up the exhaust if need be / parades
Motor seems to be running well after sitting 7yrs and from a previous owner/not knowing anything about it.
I bought a new fuel gauge and I need to install it, hopefully tomorrow. Build some side rails/rock rails and get the tags done. Almost completed.
#180
Posted 28 October 2011 - 02:56 PM
I added 3.5 gallons of fuel (tank was empty) and the gauge reads just at the top of the "E" (@ least I know @ "E" I have 3 gallons left ).
Below are pictures of the gauge resting w/the key off, and on (w/Jeep running). I'm happy, sender works fine and @ least "E" means "E" (well real close for a CJ).
Looking from the drivers seat, camera located @ the turn signal lever and on zoom.
Key Off:
Key On, guage coming up:
Gauge up:
Camera @ the turn signal lever and facing straight on.
Now looking from the drivers seat.
