JEEPTALK.net: CJ8 to M170 Conversion - JEEPTALK.net
  • 7 Pages +
  • « First
  • 3
  • 4
  • 5
  • 6
  • 7
#121 User is offline   Rollbar
Posted 04 May 2009 - 09:13 PM
Gauges installed
Gauges wired up, hope they are right
Panel wired up/items installed
Installing dash
Dash install complete
Forgot to get the seatbelt bolt out for new seat belts (didn't hurt the U-POL bed liner). Had to weld a bolt on the torque head.
Installing seat bet latches
Installing drivers seat
Installing passenger seat
Pinched finger, bracket is bent, need to straighten it out more than I did
Seats in. Need to get a longer bolt for the set belt to roll bar
#122 User is offline   Rollbar
Posted 05 May 2009 - 07:11 PM
Installed new seat belts with grade five bolts, hardened washers and loc-washers
Temporarly bolted the tops to the roll bar
Need longer feed through bolt for hard top installation
#123 User is offline   Rollbar
Posted 06 May 2009 - 04:44 PM
Installing 195* T-stat
PO used plenty of goop & blocked off the goose neck outlet
My daughter installing the master cylinder
Removed PO block off plate and installing the 6505 fuel pump
Water pump hose installed
3/4" heater hose installed
Starter solenoid installed
#124 User is offline   soflmuddin
  • Captain
  • Group: Banned
Posted 06 May 2009 - 06:19 PM
i got to jump in here and say great job! i like that you have the family involved. you get a :click: !
#125 User is offline   LostJ
Posted 07 May 2009 - 06:18 AM
what year 360 is that?
74' CJ5
00' TJ
86' BLONDE
#126 User is offline   Rollbar
Posted 07 May 2009 - 08:36 AM
1974
#127 User is offline   Rollbar
Posted 07 May 2009 - 07:35 PM
Spliced spare module for the nutter by-pass, heat shrinked connectors and greased connector
Module ready to install
Module installed
Radiator over flow jug
Need bracket for over flow jug
Radiator, hoses and fan installed
Heater hoses & fuel line to carb installed
Tranny cooler installed-courtesy of TransTech of Ft. Lauderdale, Florida
Can I do this for off-road and cut vent lines in the top of the hose?
Is this port for the vacuum advance for the distributor?
#128 User is offline   JeepinIan
  • Major General
Posted 08 May 2009 - 05:56 AM
I would just drill a couple of holes in the top of the bend. Slicing the hose would weaken it too much and allow it to split easier.
I always thought that the vacuum port for the dist was under the carb o teh manifold.
#129 User is offline   soflmuddin
  • Captain
  • Group: Banned
Posted 08 May 2009 - 06:38 AM
rollbar that looks like it is probably it. it wont be on the intake, there should be little to no vacuum at idle.
#130 User is offline   Rollbar
Posted 08 May 2009 - 08:47 AM
Thanks guy's, I found out that it is the port for the dizzy vacuum & I have mechanical secondaries on this 600 cfm
#131 User is offline   Rollbar
Posted 08 May 2009 - 02:06 PM
Look what Summit sent me. Called Lokar & saved big time going w/Summit.
#132 User is offline   Rollbar
Posted 08 May 2009 - 04:05 PM
Installed Lokar's kick down bracket
Installed radiator cap (all they had was a 16lb)
Installed foot dimmer switch
Installed fuel filter
Accel super coil (need bracket), mine is rusted but workable
Installed OC handle
#133 User is offline   JeepinIan
  • Major General
Posted 10 May 2009 - 04:55 PM
I always called this a JC handle. Some others have called it OS handle.
#134 User is offline   Rollbar
Posted 11 May 2009 - 03:37 PM
Received the air/vent cables and the front extended brake lines
Vent cables installed but the TEMP knob pulled off the hard line. Nothing like factory, maybe JB weld will hold it
#135 User is offline   Rollbar
Posted 13 May 2009 - 02:49 PM
Installed SS extended brake hose
Installed factory bump stops until I get around to newer ones
Drilling hole for manual choke installation (had one in the tool box since 2005)
Location of manual choke bracket
Manual choke bracket installed
Slide cable/sheath through the bracket and lock it down w/the lock nut
Slide choke cable through the drilled hole
Choke cable dead ended
Set desired length for sheath then cut (remove the cable from inside first)
Slide cable back through the sheath
Open the choke to set the cable, pull tight
Operate choke
Received oil back flow block off plate from Bulltear today
#136 User is offline   Rollbar
Posted 13 May 2009 - 07:34 PM
Well I think what is left is:
Battery
Exhaust
Air filter
All fluids
Grounds
Shorted rear DS
Install shifter
Tranny kick down
Axle breather hoses
Attach the two rear bump stops
Install glass & attach windshield
#137 User is offline   Rollbar
Posted 14 May 2009 - 02:52 PM
Jr taping up the windshield for touch up
Windshield touched up
Windshield installed w/new cowel rubber
Jr cleaning hard top
Hard top installed. Need to shoot it with the U-POL Raptor to match the bed
VIN Plate & charcole canister holder painted/POR-15
Brake lines installed
#138 User is offline   Rollbar
Posted 15 May 2009 - 04:28 PM
Front axle vent line installed w/stainless steel self taping screw, will add filter later
T-case vent tube installed, will add filter later
Heat shrinking connector on coil connection. After this I decided to go w/a bolted connection on the coil
Windshield vent deflector installed. Will not install dash pad, keeping it old school as much as I can
#139 User is offline   Rollbar
Posted 16 May 2009 - 12:50 PM
Ground straps to be installed
Ground strap bolted to the starter
Ground straps bolted to the engine frame mount
Drilling hole in fender for 3/8" x 1 1/2" ground strap bolt
Bolt installed (couldn't find a Brass or Copper bolt, will change out later)
Ground straps installed
Main ground strap and negative end of battery installed to the strap
Main ground strap, starter strap & engine block strap installed
Drilling pilot hole for stainless steel self tapping screw to install ground strap to negative side of battery
Strap installed for negative side of battery
Grounding & straps complete
#140 User is offline   Rollbar
Posted 20 May 2009 - 11:00 PM
Mounted coil to the drivers side fender.
Drill holes
Coil bolted down with stainless steel bolts
Splicing wire to the resistor wire (red with white stripe)
Heat shrinked, taped and read for the wire loom
Coil ends ready for crimping
Coil ends crimped
Heat shrinking coil connector ends
Coil connected
#141 User is offline   BigBlock
  • Sergeant
Posted 22 June 2009 - 09:13 PM
Nice build rollbar, i like the that raptor stuff
#142 User is offline   92SquareEye
  • Gender:Not Telling
Posted 23 June 2009 - 06:10 AM
c'mon rollbar...when is our ride at brown's? since our build competition, i've finished...wheeled it a few times and now am back to having to wrench on it again. any chance you'll be ready by Christmas? maybe santa will briing me some tires...
#143 User is offline   Rollbar
Posted 23 June 2009 - 09:52 AM
I know, I know, I just moved but here's what I have left.
1. Battery (got one from the ZJ)
2. Re-fab rear DS-DONE 9-20-09
3. Trany kick down lever for the TF-999 (trying to find one)
4. Install Lokar SS kick down cable (have it)
5. Install all fluids (rears to)
6. All thread shaft for air cleaner
6. Make plate for floor shifter
7. Install floor shifter (have it)
9. Finish paint scheme
9. Tag/Title
10. $
#144 User is offline   sgt1022
Posted 29 June 2009 - 10:30 PM
Gtreat job your build looks great. You make that U-POL stuff look easy to spray.
#145 User is offline   Rollbar
Posted 20 September 2009 - 03:58 PM
Rear drive shaft cut down & installed. Thanks for the help Scott :)
#146 User is offline   Rollbar
Posted 29 January 2011 - 02:11 AM
More pics, Jeep arrived out West last week and I'm continuing to build, getting there.
Mechanical oil line installed and dead ended to gauge in rubber hose part way then 1/4" wire loom into cab for protection
Vacuum line installed in 1/2" wire loom for protection
Vacuum line plumbed to engine and vapor canister
GM Charcole canister
Orange dot = Vacuum
Green/purple dot = PCV
Purple swirl = Tank
Green lines = Carb bowl
Fire flame = main Vacuum
Part number-17060868 BC
I do not have a carb bowl vent to hook up so I guess I leave it plugged.
Lokar cable install
#147 User is offline   92SquareEye
Posted 29 January 2011 - 08:52 AM
looking great!! :2thumup:
#148 User is offline   Jim B
Posted 29 January 2011 - 09:27 AM
I've been following this for a while and I just took a quick browse at all the pics. Looking exceptional except for one thing that is bothering me. :2thumbdown:
You have taken all of it apart, rebuilt just about everything and you went ahead an installed the seats without painting the frames, they just don't go and look like hell. :gun: Now go back to the 4 bolts, take the seat out and paint those frames. Don't let it happen again! :ax: It reminded me something out of square headlight Jeep restoration. :boxing: :cool:
#149 User is offline   TranyDoctor
Posted 29 January 2011 - 10:24 AM
almost perfect, you need one of these :empathy:
#150 User is offline   Rollbar
Posted 29 January 2011 - 12:48 PM
Yes Jim I am going to take them out and paint them, I put them in when I was in Fla just to get them out of the way. I am in the process of making the shifter plate where the stick goes so I can install the temp B&M shifter (going to have to save for the Lokar tall shifter so it looks like a stick shift tranny. I will do that last cause Peach wants the U-Pol Raptor spray in her Jeep and when she does I might shoot the frames and then I will shoot the shifter plate to match the floor.
P.S. T-Doc, that is the ugliest paper wight I have ever seen :rof:
  • 7 Pages +
  • « First
  • 3
  • 4
  • 5
  • 6
  • 7
