Shovel Tech?
Posted 26 December 2005 - 11:34 AM
I know that if the shovel does not have a pick attached to the shovel end it's a .....................................
I know if the shovel does have a pick attached to the shovel end it's a....................................................
RollBar :sneak:
Posted 27 December 2005 - 08:36 AM
Rollbar, on Dec 26 2005, 11:34 AM, said:
Ok, let's clarify a few things. We are talking about shovels that were carried by the soldiers themselves, not the shovels that were carried on the vehicles which were bigger.
WWII Shovel.
Korea... (not too sure) maybe as late as Viet Nam.
Now the same question but for the shovels that were carried on the WWII vehicles themselves. How do you know that you have an authentic shovel vs a cheap imitation Hint.... you can tell by the back of the spade, if your sharp you pick out the answer.
Posted 27 December 2005 - 10:21 AM
I have a brand new military issued shovel I got from my dad when he was in the army during vietnam. It does not have a pick on it. Just a regular fold up shovel. I will tak a picture of it tonight when I get hop and post it up.
Frank
Posted 27 December 2005 - 02:25 PM
One of scores of items that made life a little easier and safer for the World War II soldier was an improved intrenching tool. Unlike World War I where soldiers spent most of their time at the front in, in World War II the emphasis was on individual shelter and the need to construct hasty foxholes. For that reason, the intrenching tool became an indispensable piece of equipment, as necessary as a weapon in many settings.
WWII M1910
M1943 Issued around 1943 lower profile welcomed by the soldiers.
M-1951 version that added a pick, hinged and attached to the same pivot as the shovel so it too could be folded out or laid flat for storage. During the winter of 1950-51 in Korea, intrenching tools were discarded by combat units while they were actually engaged with the enemy. The reason was that the ground was frozen and the tools could not be used. The quartermaster of the Division did not become aware that these tools had been abandoned until the spring of 1951, when the ground began to thaw.
M1951
Vietnam and Later, M1967
The M-1943 basic design was finally superceded with the tri-fold shovel, known as "Intrenching Tool, Collapsible, M1967". The "Carrier, Intrenching Tool, Collapsible" was made of olive drab nylon fabric and had the ALICE style keepers instead of the wire hooks of earlier models. Later versions of the carrier were hard plastic.
The black coated metal shovel design has a handle that folds in two places, controlled by a single large nut that can be opened or tightened by hand. The tool can be arranged as a straight shovel, folded at the hinge point to be a hoe, or fully folded up so that it stows completely inside the carrier with no handle protruding as was the case with the M-1943 design. Part of the edge of the shovel is serrated to form a saw.
M1967
Posted 27 December 2005 - 05:41 PM
P.S. Ya know, when I look @ the old war footage & pictures of the GI's I often wonder what they are doing now (if alive) & what there names were & what they went through to give us FREEDOM.
Posted 28 December 2005 - 07:44 AM
Frank
Posted 28 December 2005 - 09:30 AM
Rollbar that M1951 is perfect for your M170 era. I have this one in my garage also and I just acquired an M1943 to keep as part of soldier equipment in the Willys.
The M1943 shovel has a manufacturer stamp and is dated 1945. Could not find the markings due to so much cake on paint, I called the person that happen to just give it to me and he told me is was painted the wrong color (which I knew) and that the markings were there... he actually told me the area in the shovel where they would be. I took a wire wheel and sure enough, clear as day. I stripped the entire shovel and will be painting it the correct color. I need to spray light on top of the markings so they can bee seen. Does any one here have a paint trick so the markings don't get burried other than to lighten up paint around this area
Mr. Rollbar, the question also is... will you be displaying under and mounting underneath the hood of your M170 build up "the shovel" Should we discuss how to determine the correct shovel for WWII Willys & M170 so deep down inside we know we are not carrying the usual Home Depot.
Posted 28 December 2005 - 05:20 PM
Ya, if U buy me one for my B-day, :sneak: .
Jim,
1. Strip the shovel.
2. Spray a light coat (mist) on/over the numbers.
3. Let it dry.
4. Get some candle wax or something like that & rub across the numbers to fill the voids & wipe smooth.
5. Paint the shovel as many times as U want.
6. Let the shovel dry (in the sun all day).
7. Scrape the numbers w/a tooth brush or w/very MINIMAL heat melt the wax.
8. Numbers/marking look excellent.
No We want a step by step w/pics of the process, :sneak:
P.S. I saw a shovel @ Home Depot, it looked just like yours.
Posted 29 December 2005 - 08:24 AM
I shot some light primer and you can see the markings clear as day, I'm going to now go over it with some light OD and after it dries I will try out you wax trick if I need to get it a bit thicker.
After it's all done I might take a pic of the markings so you can when you see the markings on it.
With regards to the comment of the Home Depot shovel hanging on the side of my Willys..... let it not happen again.
Posted 29 December 2005 - 03:22 PM
Jim B, on Dec 29 2005, 08:24 AM, said:
:sneak:
Posted 14 February 2006 - 08:31 PM
Tons of Shovel information with pictures, U will be impressed
Posted 16 February 2006 - 10:52 PM
Real good info on this thread on vehicle shovels
... but, if you wanted to see an authentic WWII Jeep shovel all you had to do was look at my Willys MB.
Posted 17 February 2006 - 12:06 AM
:sneak:
