Disabling Starter
Posted 26 November 2005 - 09:59 PM
I also found this thread that you might want to read up on, Jeep/Starter disable
This is part of the research that works, "Pass the ignition through both of these in such a way that the only way to start the Jeep would be to pull the parking lights on and push the brake pedal while starting".
I think it's cool having to to what is stated above.
P.S. I still would like to know about the steering wheel.
Posted 26 November 2005 - 10:43 PM
J.C. Whitney has it... Part no. AKL496731
Price is $139.99
Member of:
Posted 26 November 2005 - 11:26 PM
I'm looking to keep a stock/stock wheel appearance to the Jeep.
Thanks again,
P.S. ULTIMATE VEHICLE ANTI-THEFT SYSTEM
Posted 26 November 2005 - 11:39 PM
For the wiring - any creative approach could be used. The way this one is described, the hot starter solenoid lead would be rerouted through the parking lot/turn signal/whatever, preventing the starter from engaging. Any number of things could be done, underdash toggle, magnetic switch, push switch under the clutch. The really po' man setup is to pull the coil wire.
Just remember either setup only keeps the honest thieves out and is just a deterrent.
For a more dependable theft deterent system - see this post.
Posted 26 November 2005 - 11:43 PM
I am sure it wouldn't take much "tweaking" to make a stock wheel work. Grant also has some very inexpensive wheels and some wheels that keep a "vintage" look. I pulled my grant off my camaro - which has been on blocks longer than I care to admit. RIP.
Posted 26 November 2005 - 11:51 PM
Member of:
Posted 27 November 2005 - 11:54 AM
Excuses are the tools of the incompetent
..CISCO..
Posted 28 November 2005 - 11:30 AM
Jeepn, on Nov 27 2005, 11:54 AM, said:
I like this idea the best. Can you elaborate on the location of the wires, color code, etc and possibly post a pic
Posted 28 November 2005 - 03:25 PM
This is what ive done to mine as well. Works great as long as you remember to flip the swtich and usually I do when I leave it in places I dont trust or for long times as Jeepn stated
'98 Grand Cherokee
Ru•bi•con n.
Posted 28 November 2005 - 04:16 PM
What year(s) did Jeep go with electric fuel pumps? When FI came from the factory I'll guess?
Posted 28 November 2005 - 10:20 PM
