Cheap Kill Switch
Posted 29 August 2005 - 06:54 PM
American racing wheels and KNL air filter redid everything under the hood, so it will run for ever!!
Front push bar and dayrunner KC lights.
Just added new seats, tow hitch, and center console and soon add a 3 or 4 in lift and 31x10.50R15
Posted 30 August 2005 - 06:44 AM
david97jeep, on Aug 29 2005, 06:55 PM, said:
David97,
Neat idea, have not looked on mine and never noticed... are these two wires color coded, can you post up a quick pic showing wires and switch.
Posted 30 August 2005 - 01:30 PM
my $.02
Posted 30 August 2005 - 05:53 PM
Posted 01 September 2005 - 02:59 PM
HEI, D44 & a D300
Posted 01 September 2005 - 06:12 PM
Posted 02 September 2005 - 01:25 PM
1979 CJ7 258
(Offenhauser 4bbl aluminum manifold, Pacesetter headers, Holley 4 bbl Carb.)
4" suspension lift
1" body lift
36x12.5 SS TSL Radials
8k Warn winch
Necessity is the mother of Invention, and Cheapness is it's ugly sister.
Posted 02 September 2005 - 01:31 PM
Posted 02 September 2005 - 02:42 PM
1979 CJ7 258
4" suspension lift
1" body lift
8k Warn winch
Posted 02 September 2005 - 02:51 PM
Posted 04 September 2005 - 02:03 PM
Jim B, on Sep 2 2005, 03:52 PM, said:
I dont think anybody wants to publicly show where they have there kill switches hidden.
'98 Grand Cherokee
Ru•bi•con n.
Posted 04 September 2005 - 09:07 PM
I know where yours is :P
Posted 04 September 2005 - 10:24 PM
Besides... I like pics.
Posted 05 September 2005 - 02:03 PM
clutch wire for tj
Larger Pic Clutch Wire
This is the two wires coming from the clutch for my TJ. The wires right of the clutch arm. Hope this helps with the TJ part of this section.
