Pre-drill for ARB line HP44 4x4 shop frigged it up! & Update
Posted 21 August 2003 - 08:45 AM
SO i decieded to take my HP44 home otherwise 4x4 shop will make it worse!
SO i will do the drill for new hole, how about i drill 1-2" hole of RE bracket bridge to clearence the ARB line then drill 1/4" (is that correct, ARB line 1/4" to drill the pumpkin?) into the pumpkin ? hows that sound?
I will cover ARB locker with plastic or clothes and have HP44 diff face downward so the metal sharp will falling onto the floor..
Heres the pix
As you can see what they did with my front cover diff :( !!
Thanks!
JAke/YEOW
Posted 21 August 2003 - 09:06 AM
And, if you did pay them, are you gonna ruin any warranty on the internal work they did if you reroute the line yourself?? Cuz you may need it.
I would find another shop to check out what they did.
Sorry I can't answer your other Q's intelligently, I have no experience w/ ARB's.
HB
Posted 21 August 2003 - 09:12 AM
They installed my OXs and it works flawless and awesome..
My guess that they dont use their common sense!
Yes i only paid $150 after they accepted to reduced the price on installation job. no they wont viod it if i plug it into the different route.
Thanks!
YEOW!
Posted 21 August 2003 - 11:21 AM
What a mess!! :tdown: Since they are probably not that good of a shop (speculating here which is not good), they must have follow the instructions very well on the Ox install. That is probably why you are not having any problems. Sometimes the guys that think that know it all will not read the install notes as they are "pros".
After seeing this I would have just taken my TJ and walked out out there. With regards to the cover I would not rtv it. Take the cover off and weld the hole, make sure it's done right. Follow the instructions in your arb manual for drilling the hole on the diff. I personally would not drill that big of a hole for the arb line to clear your mount. I think I have some pics of my truss on my personal website that you can see.
Please keep us posted on how it goes and post a pick of your final fix. Btw, can you take a pic of your bracket without the red or any obstruction so we can see better?
Posted 21 August 2003 - 11:27 AM
Forgot, you don't want to bring your line out through that bracket. The arb hole will be on top of the diff which will have a fitting. You then install your blue or stainless steel line to it, bringing it through and up the truss. See if you can hunt my pick down, if not let me know.
Posted 21 August 2003 - 06:58 PM
They told me they did follow the instruction until they dont know what to do with RE bracket and afraid to make a hole for ARB line on top :boiling: and i said " well, why didnt you call me then!!!"!! DOH!
will keep upi guys update!
Thanks!
YEOW!
Posted 23 August 2003 - 10:49 AM
I found a pic of my front pig that might help you see which way the ARB line was installed. Don't remember if I had this one on my web site or not.
I had taken the truss off so you will not see it in the pic. However the line goes up & through a small hole of the truss itself.
Posted 28 August 2003 - 08:29 AM
I'd find a rubber bushing to go inside the hole in the bracket and around the air line (a cork with a hole drilled in it) so that air line (even with the spring protector) won't chaff on the bracket, if it was me. Cheap insurance............
HB
Posted 28 August 2003 - 09:09 AM
I disagree with Brad on one thing... it does not just look better, it looks 150% better!
Did you weld the hole on the cover or did you just get a new one?
Posted 28 August 2003 - 09:28 AM
Yup, my friend welded the hole, so its all good even i have a D44 cover as a spare !
Thanks!
YEOW!
