Installing ToughStuff FENDER Protectors
Posted 13 August 2003 - 07:50 AM
For those of you who are not aware of this, one of our own, Hellbender has decided to pull together a small team of folks and start a business making some rather unique Jeep Parts and Accessories..
If anyone has an interest in learning more about Hellbenders product line here is the address to Tough Stuff Products, Inc.
http://www.toughstuffproducts.com/
I have had the chance to install and review several of these new products. I thought I would share my observations and do a write-up of installations instructions that others may find useful.
The products I have installed are the Paint Protector Products for my Jeep’s Fenders, Doors and Tailgate Sill plate, and a Stainless Steel Tailgate Bump Guard.
As I get the time I will put up instructions for each of these.
Fender Protectors
These are really neat folks. They simply stick on, and provide what appears to be a very tough surface to protect the tops of my Jeep fenders from the tools that I am always placing up there.
The material being used appears to be some type of semi-flexible plastic with a rough textured finish to it. Sort of like Bed Liner, only much more uniform and fine in texture.
I don’t think I have ever seen anything quite like this stuff. They did a great job of covering up the many little dents and scratches accumulated over the last 6 years in the tops of my fenders. (I lay my tools there all the time.)
Here’s a picture of one of my fenders with the protector in place.
General Instructions
As I said, I installed three of the paint protector products. Here are a few thoughts dealing with the installations that you may find helpful.
All the Tough Stuff Protective Products I installed appear to use a waterproof contact type adhesive. Folks this is incredibly sticky stuff.
Here are a few thoughts that I would recommend that might aid in your installation.
1. Make sure the surface temperature of your Jeep, the Tough Stuff Protectors, and the air temperature are above 60 Degrees F .
2. Don’t try to install these in direct sunlight. This glue is incredibly sticky and the heat really seams to activate it farther. I made sure my Jeep was in the shade and cooled down.
3. All the Paint Protector Products come rolled up in the box for shipping. I found it helpful to lay them out on a clean flat surface in the sun for a minute or too before installing. This helped get the curve out of them and made for an easier installation.
Here’s a picture.
4. Clean! Clean! Clean!!!!! Proper surface preparation is vitally important for proper adhesion. I cleaned the tops of my fenders 4 times using 70% Isopropyl Alcohol that I had sitting in my bathroom medicine cabinet for years. This gets old wax, road film and grease/oil off the surface of the paint and lets this super sticky contact cement adhere the paint protectors in a way that I doubt would ever come off.
(Check your bathroom medicine cabinet or you can get this at Wal-Mart / K-Mart / CVS / Rite Aid for about $0.53 a bottle.)
5. DO NOT remove the Adhesive Backing Paper from the back of the paint protectors until the instruction that come with it tell you to do so. Trust me on this one folks!
Tools:
Here’s a list of the simple tools I used to install the Fender Protectors
Paper Towels
Basic Hand Tools
Single Edge Razor Blade
Masking Tape
Sharp Scissors
Detailed Instructions for the Fender Protectors
Step 1 - Remove Hood Latch Components
I did my installation on my TJ. I don’t thing it is necessary to remove any hood latch hardware if you are doing this on a CJ, but I don’t know for sure.
I do know the hood latch hardware does indeed have to be removed to put the Fender Protectors on a YJ.
Open your hood fully. It may help me during the installation to rest the hood against the windshield frame.
Posted 13 August 2003 - 07:52 AM
On my TJ this was a 15 mm nut.
Remove your Rubber Hood Bumpers.
PLEASE NOTE: If your rubber hood bumpers are getting old and weather cracked, you may damage them by removal (You could get a new set from your Jeep dealer for a few bucks or simply trim the Fender Protectors around them.)
The Rubber Hood Bumpers are held in place by two small nipples that extend through holes on the top of the fender. The bumpers can be removed by carefully pulling to one side, then wetting underneath (to lubricate) with water, window cleaner or alcohol. Work them side to side, they will come out.
Here is the Hood Latch and Rubber Bumper you should have removed from each fender.
Step 2 – Cleaning / Surface Preparation
*** Surface CLEANING is vital for proper adhesion. I cannot over emphasize this Folks!! ***
Place the Fender Protectors on top of your fenders where you would like to install them.
Take note of the area that the Fender Protector covers, plus another ½-inch around the outside edge of the Fender Protectors.
Remove the Fender Protectors and thoroughly clean each area three (3) times.
Use a generous amount of rubbing alcohol and clean paper towels each time (rub hard). Allow the alcohol to air dry on the top of the fenders.
Clean each fender top one more time (fourth time). This time dry the alcohol off with a clean dry paper towel. If you see any dirt/wax film streaks while doing this repeat the cleaning process until spotless.
This is important folks. Get carried away with your cleaning effort.
Step 3 – Installation
*** The tops of your fenders are clean, right? ***
Place the Fender Protectors on your fenders and check for the proper fit. You should see a 1/8-inch to ¼-inch gap around all outside edges.
If you find any areas need trimming, trim with a sharp scissors or a razor to fit to your liking. Mine fit perfectly without any trimming.
Tape the Fender Protectors in the proper location using masking tape. Make sure there are no voids or air bubbles under the Protectors.
Double-check the location of your Protectors. You might want to close your Jeep’s hood to make sure you are satisfied with this location.
Posted 13 August 2003 - 07:54 AM
Peel the adhesive backing paper off the un-taped area of the Protector;
Then tear the paper off the rear half and discard.
Lightly lay the rear half of the fender protector onto the fender. DO NOT rub down hard until after the installation is complete, but DO make sure there are no voids under the Protector.
If the location is off, you can pull it up and relocate the Protector before final rub down.
Remove the masking tape and carefully peel the adhesive backing paper off the front half of the protector.
Continue to lay the front half of the Protector down onto the fender. DO NOT rub down yet. If the location is off you can lift the protector and re-align it.
When you are satisfied with the alignment and installation, use a clean dry paper towel or the Protector Backing Paper and thoroughly rub down the enter Protector to finish adhesion.
Rub from the center of the Protector out toward the edges. This will help eliminate air pockets.
If you have an air bubble you cannot work to an outside edge cut a small slit in the center of the bubble and press the air out.
Posted 13 August 2003 - 07:55 AM
Locate the mounting holes for the rubber bumper and hood latch under the Fender Protector with your finger. Press down to make small indentations in the Protector over the holes.
Press a Philips Head screwdriver into each indentation to open up the five (5) holes in the top of the fender needed to mouth the latch and bumper.
Enlarge these holes by rotating the screwdriver to their proper size.
To install the Rubber Bumper first lubricate the two nipples with water or a window cleaning solution. Then insert a small screwdriver into the holes on the top of the rubber bumper and press it into place through the Protector and into the fender.
Reinstall the Hood Latches using the 15 mm nut from the underside of the fender.
MAINTENANCE
There doesn’t appear to e any real maintenance required for any of these paint protector products. The instructions tell you to just clean them up with a soft brush or sponge and some soapy water.
They also tell you to be careful you do NOT direct a pressure washer spray at an angle around the edges of the Protectors for 14 days after installation. This is to ensure the adhesive cures properly.
That’s all I have on the Fender Protectors folks. Of the handful of Touch Stuff Products that I have installed on my Jeep I like these the best!
I will do a much shorter write-up on installing the Door Protectors, Tailgate Sill Protector, and the Stainless Steel Tailgate Bump Guard as time permits. (Life just keeps getting in my way sometimes.)
If you have an interest in seeing some of the other products Hellbender and team are bringing to market you can check them out at their web site.
I cannot and do not in any way wish to give direction on future products, Hellbender can do that, but it is my understanding a much more complete and robust product line is in the work. I do know the lead engineer here and I can tell you folks, you’re going to like what you see coming down the pike.
Brad (Hellbender) and his team have been major contributors to the Jeeping Forums for years. Personally I think it is wonderful that they have come together to offer some rather unique products to the hobby. I wish them all the success they are able to earn in the market place!
From what I have seen in my limited exposure to what they are already producing the quality is first class!
Frank
PS: I’ll get some of the other instructions up a bit later.
Posted 13 August 2003 - 10:45 AM
Looks like a winner! Excellent write up as always even for the most simple.
What kind of texture is it? Is it smooth or gritty. If it is smooth I wonder if it will work for the rocker rails to get extra grip as I do not like the gritty stuff much.
Btw Frank, you have caused a change in the limits of the forum. I've asked our administrator to allow more pics to be posted on a single post along with a bigger buffer for the text so you don't have to split the write up into 3 different posts. Let me know if it works for you in your next review. Progress demands changes!
Posted 13 August 2003 - 12:12 PM
I tested 4 different hardness compositions and these worked the best, I have had the origonal prototypes on my fenders for about 3 years now, they still look like new.
The Rocker Guard Gaskets (a different product to go under bolt-on rocker guards to protect the paint) are made of a softer, resiliant material, they work really well under rear corner guards, also. They would be more of a non-slip (rubbery) surface with a very slight texture.
Thanks for posting the write-up Frank!
HB
Posted 13 August 2003 - 01:23 PM
Will this material work or do you have another product that I could use to stick on the rocker protector itself to prevent slipperiness as I climb in? I now have gritty tape and I hate it.
Posted 13 August 2003 - 01:46 PM
The only downside to this material in an application like you are describing is if you tried to bend it around a tight corner, this material, being rubbery and having a "memory" (unlke the Protectors, which are designed for this), may overcome the adhesive bond in high heat applications (FL sunshine). I think they would be fine on a flat surface.
Is this big enough to fit? If so, let me send you a sample to see if it works, I would trade it for a little writeup when you have the time, Fair enough?
HB
Posted 13 August 2003 - 02:17 PM
You've got a deal, I'll take off the crappy gritty stuff I have now and do the testing on your new rubber stuff. Since my rocker is on an angle and is not really a step, any non slippage will help. It will be installed mostly in the flat angle area of the protector so it will have no bend in the material. I will trade you for some pics and my personal opinion.
Don't ask me to take off the rocker protection to also put it on the inside against the body. It was a royal pita to install these and I'm not about to go through that again... if I was only retired. :spike:
Posted 14 August 2003 - 06:20 AM
Thanks Jim.
I have a tendancy to get a bit carried away with things. But pictures sure do help to get points across.
I'm too old to learn how to do my own web site, so I se these forums to put the info up.
Have a great day, I plan to,
Frank
Posted 15 August 2003 - 11:28 AM
Posted 15 August 2003 - 01:24 PM
Both in Black and Clear (textured)!
Here's a link.......
http://www.toughstuffproducts.com/jeep/pai...protectors.html
Thanks for the inquiry,
HB
