Admin
I just posted and the time is 1 hour behind.
Jack
Time off
Posted 12 April 2005 - 04:00 PM
Posted 12 April 2005 - 06:48 PM
Go to "My Controls" (User control panel), you will find a menu on the left towards the bottom called "Board Settings", check the box for "daylight savings time".
Your postings and all the other Board times should change and be correct.
Let me know if this helps.
Admin
Posted 12 April 2005 - 10:25 PM
That worked, thanks. I guess I didn't know that I had to do that. :sleep:
