Dual Batteries v. Stronger battery
Posted 27 July 2003 - 02:33 PM
Any comments are appreciated.
Dan
4.88 gears / belly-up skid
3" lift & 33" Goodyear MT/R
Toys By Troy full sports bar with back add on and spreader bar
ARB Bull Bar / AEV rockerguards
Off Your Rocker Corner Guards
Warn Winch / Safari Snorkel
IPF off road lights / Currie bumper & tire carrier
Posted 27 July 2003 - 03:29 PM
They test their winch & others, both electric & hyd.
I highly recomend getting your FREE Cd to educate your self b-4 you buy.
P.S. 500amp won't last long.
You may want to up grade your alt also, but that is another story.
Posted 27 July 2003 - 05:53 PM
anthony
Posted 27 July 2003 - 11:01 PM
What I would do (notice I say I), is use my stock battery until I kill it. Why throw that money away.
On my 97 TJ, I think stock alternator is around 117amp, switched out to 120 when I put the welder in only because it was part of the package. The new models of the welder I have now use your stock alternator. I have a QuickAirIII which draws 50amps, Arb Compressor 30amps, and Warn 9500 electric winch. I do not have dual batteries. After I killed my stock battery back in 1997 I purchased an Optima Yellow Top. I placed this battery in service late 1997 and I still have it under the hood.
The trick here is to get a dependable deep cycle, preferably a sealed battery so when you get caught in an off camper, long climb situation, you don't start to run battery acid all over inside the hood. There are other batteries beside the Optima that other Jeepers have been using within similar specs, I've had such good luck with mine that I will not look at anything else when it comes time for replacement.
I've used my winch plenty to pull others and myself, use both of my air compressors all the time and been fortunate enough not to have to use the welder on myself but have welded others plenty. Will I ever install a dual battery setup? Can never say never but as of now my future plans is just to replace the Yellow Top with another when it goes. :strong:
Posted 31 July 2003 - 05:54 PM
While the below write-up does comment on an Optima battery, I believe there is much in it that is applicable to your question about using a dual battery setup or a BIG single battery.
http://www.stu-offro...isc/battery.htm
Posted 01 August 2003 - 05:48 AM
ps: I have yellow top Optimas on both our jeeps. One is about 4 years old now and going strong, newer one on my TJ is about 2 years old. Never have had a problem with either.
Posted 01 August 2003 - 06:51 AM
BUT you put in 2 nice (and large) batteries and that same stock alternator will have to charge both of them up........if you drain one under winching loads (or what have you) the alternator can and will charge it back up without too much trouble..BUT if you kill them both...then you might run into trouble.
Here's why...and yes flame me because in highschool I had a 'honda' and I had the 'boom boom' stereo..I did not see the light until I was about 22.
Had the Honda and the stereo system. Was starting to pop inline fuses for my largest amplifier. So being ignorant I kept putting in larger fuses...until finally I smoked the amp's internal power supply.
Had my electrical system checked and sure enough I was not getting enough amperage or voltage to that amp. I had an 1100 CA battery and the amp(s) was discharging it and the stock alternator could not keep up....so to make the point......make sure the rest of your electrical system is up to the task of 2 batteries if you indeed use 2 batteries.
So you could start losing accesroies if your alternator can;t recharge both batteries and keep up with the amperage/voltage demands of your rig.
BUT I am with everyone else thus far and say kill the stock battery and then yellow optima (or equivalent).
Posted 01 August 2003 - 09:00 AM
Superman,
No flames here, but thank you for the morning entertainment. :lroll: :lroll:
Don't feel bad, it also took me a few years to realize it myself.
Posted 01 August 2003 - 11:12 AM
I use my Jeep for camping a lot with my 2 boys, many times we will use it for 2-3 days at base camp running stereo, airing up stuff, etc. etc. on the main Battery, when my boys forget and leave something on for a day or 2..................
I just flip the switch and we can still start :jump:
We are usually alone and at least 20 miles form the nearest help.
I have also left my Jeep at the airport and come back to a dead battery....I just flip the switch and away I go.
It also halves the winching load on each battery, or doubles the time, or both, at MY option.
If my Jeep is running? No problem, both batts together, half the load on everything.
Jeep drowned out in the middle of the river? disco one batt, pull it till it's dead, and still have a full battery to restart the rig.
My situation is probably different from yours, as 90% of my wheeling is by myself, and I have to be totally self-sufficient. If I always wheeled with others, I would be completely fine with a good single battery and a good set of jumper cables.
Just some thoughts,
HB
Posted 02 August 2003 - 02:59 PM
sorry for being offtopic
