My ABS came on some time ago and I read the code and it was the ABS pump so I picked one up at the U pick and now the light is still one and I was told I need to have a special scan tool to prime the pump. Is this true and do you know who has a scan tool that can do this?
WJ ABS Pump
Posted 14 December 2014 - 08:32 PM
Did you ever locate a scan tool, did the pump need prime?
I have a friend that might have the same issue and don't know what to tell him since I never ran across this.
Posted 14 December 2014 - 11:02 PM
Hey jim. No I did not need the scan tool. I made a pressure brake cap. I bought a second brake fluid cap I drilled it and put a valve stem on it and put 15 lbs of air pressure and bleed my brake's that way. If you friend needs help have him contact me I can help him out.
Ruben
Posted 15 December 2014 - 01:35 PM
Many thanks, I'll let him know and pass on the info.
I have to say that your workaround was mighty fine ingenuity on your part.
