JEEPTALK.net: EVO Rubicon Swaybar Disconnect - JEEPTALK.net
#1 User is offline   MrSig
Posted 12 October 2014 - 03:18 AM
NoLimits Manual Rubicon Swaybar Disconnect
The Factory Rubicon Swaybar Disconnect is a great feature but is prone to breaking, shorting out and all around being annoying. The EVO NoLimits Manual Disconnect now allows you to defeat the overly troublesome computer system that operates this very cool feature that Rubicon Model JK’s come with. The manually operated EVO NoLimits Swaybar Disconnect now allows you, with a few turns of the dial, to disconnect your Rubicon Swaybar at anytime, in any gear, and with any amount of articulation. No need to bounce the vehicle, no pins to pull or fighting to reinstall, no swaybar links to remove, no punctured tires from removed swaybar links, just unrestricted articulation. Back to the highway… Simply turn the dial a few turns in the opposite direction on level or uneven ground and your swaybar will fully reconnect by itself for highway use.
For sale Used $50.00 firm. Pick up only.
CEO of Black Sheep 4x4s
#2 User is offline   MrSig
Posted 05 May 2016 - 04:09 AM
Sold!
