I replace my wife's radiator w/a 3 core (she had a two core original) & after doing the timing chain I noticed (U have to remove the radiator to do the chain) the bottom of the new rad had been rubing on something & if it wasn't taken care of it would rub a hole in the bottom of the radiator. The rubbing came from the new rad sitting on top of the steering box hard lines that go into the box. & cut a two inch piece of heater hose & slid it betwen the two.
So check your's so U won't be left high & dry :sneak: .
Radiator Rubbing U have to look @ this/check your's.
Posted 27 February 2005 - 12:20 AM
Posted 27 February 2005 - 10:00 AM
Rollbar,
Did you notice any difference in temperature or performance between the 2 & the 3 core Would you do it again if you had to I'm still running with the stock two core & never had a problem.
Posted 27 February 2005 - 03:19 PM
Yes, I noticed a big difference, I can let it idle all day long & it will not get hot even with a/c.
I had a 180* stat in it & the heater would only get warm if that so I removed the 180* & installed the 195*, it seems to run better & the heat is very good. My gas miliage went up w/the new stat, it seems to burn the fuel better w/a hotter engine.
Even w/the 195* stat I can let it idle for a long time & not worry about it.
I get my 3 cores for $119.00 + tax from Cold Air Distributors.
When I buy the radiator I tell'em I have A/C (which I do) & a automatic, this way on a manual tranny U can either use the bottom (tranny cooler) for a oil cooler or save it for when U install a auto tranny.
Posted 28 February 2005 - 07:34 AM
rollbar, on Feb 27 2005, 03:19 PM, said:
When I buy the radiator I tell'em I have A/C (which I do) & a automatic, this way on a manual tranny U can either use the bottom (tranny cooler) for an oil cooler or save it for when U install a auto tranny.
Trick idea! Especially for a cooler.
