JEEPTALK.net: Headlights always on - JEEPTALK.net
Headlights always on when ign is in run position
#1 User is offline   Cj7fanQTnot
  • Private
Posted 19 June 2013 - 05:09 PM
1980 CJ7. When I turn ign to run position the headlights come on and the gray with black T and gray with white T that are together get hot where they go into the high beam switch. The White T goes to lights through firewall and the Black T goes back into harness under dash.
This happens even when unplugged. The light indicator comes on but wires do not heat up if the headlight bulbs are disconnected. Relay works and even tried a replacement, no luck. All grounds test strong.
#2 User is offline   JeepinIan
  • Major General
Posted 20 June 2013 - 05:44 AM
If you disconnect the headlight switch do they go off? It has to be either in the headlight switch or the harness that leads to the switch.
#3 User is offline   Cj7fanQTnot
  • Private
Posted 20 June 2013 - 10:46 AM
They stay on with headlight switch disconnected and high beam switch disconnected. the only go off if I disconnect the firewall plug or ignition totally.
#4 User is offline   JeepinIan
  • Major General
Posted 20 June 2013 - 10:52 AM
You have a harness short which needs to be troubleshot manually. Was the wiring harness cut/burned/damaged/altered? Was anything changed between the time it worked correctly and when it started this?
#5 User is offline   Cj7fanQTnot
  • Private
Posted 20 June 2013 - 11:17 AM
Nothing that I can tell that is in the headlight or ignition curcuit. Also, as far as I can tell eveything else works properly so I assume it is not talking power from something else that needs it. The only thing I can think is to trace back the the gray and black wire into the harness since that is where the heat comes from. this involves uncovering the whole harness and finding the problem.
I was hoping to avoid that. I am decent at electrical troubleshooting but I think this will take 10 hours if I fly blind. I am wondering if there is a plug that may be melted and jumping or at least be able to eliminate half the harness. The trouble I have is the homebrew hybrid wiring I am dealing with. It is frustrating since it worked before and I didn't plan on it popping up. I knew brakes and carb etc from sitting.
#6 User is offline   Cj7fanQTnot
  • Private
Posted 20 June 2013 - 12:17 PM
Posted ImagePosted Image
the lone wire off the relay connects to the E brack to sense when it is on. The other wires go into the plug for highbeams. The two gray wires put together are where it gets hot and the black tracer goes into harness.
#7 User is offline   JeepinIan
  • Major General
Posted 20 June 2013 - 12:46 PM
Does the wire to the center post on the high/low switch have power all the time (when key is on)? It should only have power when the headlight switch is on for the headlights, not the parking lights.
Check this link for a wiring diagram. :click:
