Front axle options 44s 60s??
Posted 30 December 2012 - 06:02 PM
4" Rough Country
36x15.5x15 Mickey Baja MTZs
2" SJ Body lift
RC Tube Fenders
Posted 30 December 2012 - 09:52 PM
Posted 01 January 2013 - 08:36 PM
Posted 01 January 2013 - 08:47 PM
4" Rough Country
2" SJ Body lift
RC Tube Fenders
Posted 01 January 2013 - 08:59 PM
It help me too, I was about to look for axle swap to help my brother.
Posted 01 January 2013 - 09:27 PM
http://miami.craigsl...3476160145.html
http://miami.craigsl...3507535902.html
Also found this guy. Looks like its a 9", my question is the 44. I cant tell if thats a usable 44 for a swap.
4" Rough Country
2" SJ Body lift
RC Tube Fenders
Posted 02 January 2013 - 11:47 AM
Posted 02 January 2013 - 01:20 PM
Thanks for the info
4" Rough Country
2" SJ Body lift
RC Tube Fenders
Posted 03 January 2013 - 12:25 AM
Posted 03 January 2013 - 03:57 PM
Posted 17 January 2013 - 10:44 AM
To fit a TJ the stock 60 will need the following;
- First, it'll need to be completely disassembled and cleaned with a wire brush. (I can do this part.)
- Second all the brackets and the inner C's need to be cut off. (I can not this part myself.)
- Third, the tubs themselfs are cut down to the proper length. (I do not have the proper tools to make this happen smoothly.)
- Forth, sleeving, inner C's attached then welded, then all new brackets for a TJ suspension need to be welded on. (I definitely can't do any of these steps.)
- Fifth, housing reassembled. (I can do this part.)
Also, in addition to the cost of the raw axle, the brackets themselves are almost $500. The orignal axles can be cut down to the new size for about $75 a piece. You will probably want to consider things like replacing seals in the hubs, possibly switching lug bolt pattern, (5x5.5 6x5.5 8x6, I do not think they make a 5x4.5; you will need new wheels). All of these will add cost a little by litte. Dana 60 is out of Dan's price range of $1,200 for a TJ. If I knew a welder that wanted to do the work on the housing for a decent price I'd do this swap though.
Currently I just have a bunch of parts I'm trying to make into a Jeep.
Posted 17 January 2013 - 10:53 AM
dan080290, on 30 December 2012 - 06:02 PM, said:
With that budget I'd try to find a TJ Rubicon axle housing. It's a Dana 44 housing and carrier, your stock hubs and out will bolt up. You will need 30 spline axles, if you can find then, use Rubicon axles will be cheapest. You'd then be running what stock Rubicons originally came with. Make sure you change out all the busing with nice fresh ones and set the alignment right. If you grab a Rubi locker you'll also have a front locker. If you do all the work yourself you should be able do that for about the price your looking to spend.
Posted 05 October 2014 - 09:10 PM
