JEEPTALK.net: dash / head light issue - JEEPTALK.net
#1 User is offline   Twshutika
  • Corporal
Posted 13 December 2012 - 03:24 PM
i have a 2000 wrangler 2.5 L.
the issue i am having is this.
i can have either head lights, running, turns, tails, brake lights /
OR have dash lights, running, turns, tails, and brake lights.
i can't seem to have my headlights work the same time i have dash lights.
i replaced the headlight switch and that didnt fix any of the problems, all the fuses are good, grounds all looked fine.
i spliced into the dash lights about 2 years ago for some dash mounted switches, but that spliced connection seems fine.
any help or suggestions on what to look for next or any hints on something that could be causing this problem would be greatly appreciated.
#2 User is offline   Rollbar
Posted 13 December 2012 - 04:46 PM
Check bulbs/volts.
Cut old splices out and re-splice connection.
Check circuit.
#3 User is offline   Krocker
  • Sergeant Major
Posted 13 December 2012 - 09:58 PM
wiring seem to be the big issue here
yeah, check the circuit might be wrong wiring connection.
