JEEPTALK.net: Ashley's 1980 CJ7 Laredo Build - JEEPTALK.net
#1 User is offline   Rollbar
Posted 21 November 2012 - 02:06 PM
Ok guys, I'm turning this over to Ashley. Her first Jeep and she has work to do. I will help her but she will do the majority if the work.
Here she is in her Stealth mode getting her Black Ops 2.
http://www.reno4x4.c...09&d=1353522272
http://www.reno4x4.c...10&d=1353522282
Carb Question:
Thankd,
Jim
#2 User is offline   Rollbar
Posted 22 November 2012 - 08:05 PM
We rebuilt the carb today and a few other odds and ends.
#3 User is offline   Krocker
  • Sergeant Major
Posted 27 November 2012 - 09:20 PM
you guys seem to be going a nice job! keep it up!
I'm also learning here...
#4 User is offline   Rollbar
Posted 27 November 2012 - 09:23 PM
Update: Headlights didn't work-Tail lights didn't work.
Solution: Replaced high beam switch and fuse for the brake lights.
All works.
Next, to change the plugs/wires.
#5 User is offline   sgt1022
Posted 29 November 2012 - 05:56 PM
Looks good. Did you ever find out which carb you have? The number on the side of the carb you asked in the video is the size of the venturi. They came in 1.08, 1.14, and 1.21, not positive about the 1.14. The 1.08's came on small v8's and big Inline 6's. There should have been a small metal tag on top near the horn. It would've had the numbers to identify which kit you need. I found different jets while scouring boneyards, but also Carbs Unlimited carry a large selection of jets to fit these Motorcraft carbs.
#6 User is offline   Rollbar
Posted 29 November 2012 - 06:04 PM
Looks like 2100.
No tag and there are some numbers on the throttle side on the base plate. I wrote those down.
Fires right up at the touch of the key and two pumps.
#7 User is offline   Rollbar
Posted 01 December 2012 - 10:16 PM
Ashley changed out her plug today. Found two platinum plugs in the passenger side rear. Black, smelled like fuel (probably due to pre-rebuild of carb). One was clean and had a little oil on the electrode. She does plan to rebuild the motor. Fires right up though.
Update coming.
#8 User is offline   Krocker
  • Sergeant Major
Posted 02 December 2012 - 09:37 PM
what are your plans with those plugs?
#9 User is offline   Rollbar
Posted 02 December 2012 - 10:49 PM
Garbage
#10 User is offline   Krocker
  • Sergeant Major
Posted 09 December 2012 - 09:13 PM
I guess so, Try to ask someone who needs those plugs it might help others.
#11 User is offline   Rollbar
Posted 10 December 2012 - 01:38 AM
View PostRollbar, on 02 December 2012 - 10:49 PM, said:
Garbage
?? Plugs are garbage!
#12 User is offline   Krocker
  • Sergeant Major
Posted 11 December 2012 - 09:02 PM
it depends if it's useless you can put it to garbage.
#13 User is offline   Rollbar
Posted 12 January 2013 - 11:42 PM
Ashley changed out her Alternator and Fuel pump. Running a lot better.
Pic on iPhone so I can't upload.
#14 User is offline   Rollbar
Posted 22 January 2013 - 12:47 PM
Taking a break right now -8* weather.
#15 User is offline   Rollbar
Posted 13 April 2013 - 11:54 PM
Break is over. Go to the link for updates-to many to post on other forums and I'm using my iPhone and upload via TapaTalk which is very easy.
http://www.reno4x4.c...do-Build-Thread
We installed the new gas tank/sender, new bumper (sweet bumper).
Now she needs a winch for her Jeep :nervous:
#16 User is offline   Rollbar
Posted 02 August 2013 - 06:10 PM
To see the latest go here - http://www.reno4x4.c...do-Build-Thread
