Peaches 1980 J-10
Posted 04 June 2012 - 02:56 PM
Posted 04 June 2012 - 05:02 PM
Please due the round conversion on the headlights, she does not deserve this.
If you round it, might take the sweetness of the old look away though.
Posted 04 June 2012 - 05:41 PM
This is called the Gladiator Grill.
I kind of like it.
Posted 04 June 2012 - 07:16 PM
Posted 04 June 2012 - 07:19 PM
I have to check this one out, hopefully change fluids/overall check and paint/interior, but U know how that goes.
Posted 04 June 2012 - 07:49 PM
Posted 05 June 2012 - 07:42 AM
She will be pimping.
If you can't get that one go with the Rhino Grille.
Now I'm convinced that you need to get rid of the squares.
I'm going to move this topic to the Vintage Corner forum.
Posted 05 June 2012 - 10:42 AM
Posted 05 June 2012 - 07:27 PM
The stuff you see under the Jeep is called cotton. We have trees here that put off a lot of that stuff and it is flammable. It should come off w/a pressure cleaner.
Thanks again for all the help,
Jim
Posted 06 June 2012 - 10:11 AM
Posted 06 June 2012 - 10:46 AM
I have to pressure clean the underside so we can see better.
Posted 06 June 2012 - 12:19 PM
http://www.fsjjeeppa...com/trcapa.html
Posted 06 June 2012 - 12:53 PM
Posted 06 June 2012 - 01:10 PM
Posted 06 June 2012 - 01:16 PM
Jim
P.S. Peach wanted to get rid of the bench seat and put buckets in.
Posted 08 June 2012 - 12:58 AM
Posted 10 August 2012 - 09:56 PM
Need to buy 8 bolts to fit the exhaust manifold where the smog stuff was, then on to the rest of it.
I put some MMOil in each cylinder to loosen up the rings just in case.
Took off the cut power steering hose and did a few other things.
Next to do a compression test (not sure if I will get an accurate reading w/wet cylinders).
Then gunk it (Royal Purple) and pressure clean it.
* Need some help on this one:
I'm going to change the oil before I crank it (been sitting and it is black). Holds 5 Qts.
I'm thinking 3 Qts of oil and 2 Qts of Marvel Mystery Oil to help loosen up some stuff - OR - 4 qts of oil and 1 Qt of MMOil.
What say ye!
Posted 11 August 2012 - 07:26 AM
What say ye!
was the motor seized or did it turn freely if it turned freely change oil and start it , if it misses, knocks or blows excessive oil then start to worry.
my old 68 firebird sat since 1991 changed battery, oils, fitters, water pump, fuel pump, wheel cyl, master cyl, wiper blades and of course tires. (basically anything that was rubber and could fail)started and drove to PGH this year and presented to my son for graduating as an Engineer from Penn State
Posted 11 August 2012 - 11:26 AM
Maybe I will add 1 Qt of MMOil and drive it around/let it idle.
We are going to work on it today.
Thanks Doc,
Jim
Posted 11 August 2012 - 03:37 PM
MMOil sat in the cylinders over night.
Today I cranked it over to get most of the MMOil out of the cylinders.
Have oil pressure.
Getting ready to put three gallons of gas in the tank and fire her up.
Not 100% sure there is old gas in the tank but after 2.5 yrs + in the heat of NV I"m sure it evaporated.
Not sure if the tank leak has been fixed but will soon find out.
Will update later.
Jim
Posted 11 August 2012 - 04:59 PM
Posted 13 August 2012 - 10:37 AM
Posted 13 August 2012 - 01:24 PM
P.S. 80% clean-get your $$ ready
Posted 14 August 2012 - 02:59 AM
#25
Posted 17 August 2012 - 08:47 PM
#26
Posted 21 August 2012 - 10:27 PM
So I will drop the tank and swish it around w/the fuel in it and install a new sender.
Question(s):
1. Should I put some Stay-Bil in the tank to help loosen it or just swish it around w/the new fuel in it?
2. Does the J-10 have a circuit board for the gauges or wires like a regular Jeep?
3. If the circuit board is bad, where can I get a new one?
Thanks again,
Jim
#27
Posted 28 August 2012 - 10:09 PM
#28
Posted 17 January 2013 - 12:45 AM
