JEEPTALK.net: 11" lift, Hack N Tap SYE, steering - JEEPTALK.net
#1 User is offline   xjcerokee
  • Corporal
Posted 21 April 2012 - 11:06 AM
I have been building up the xj slowly and finally got around to the sye. I purchased the hack n tap kit from iron rock offroad (http://ironrockoffro...tegory_Code=XDT) as well as thier steering (http://www.ironrocko...tegory_Code=XST) which I have been very happy with on and off the road. I am running a stock steering stabilizer and no death wobble. I also am currently running rustys 9.5" coils with 2" spacers on top.
Heres the sye install:
Started by cutting the output shaft with an angle grinder while it was spinning in reverse. The cut actually came out great
Then I drilled a pilot hole, main hole, then tapped it
bolted on yoke with some red threadlocker and the refurb stock front ds
coil spacer install and steering
going to level out the rear with the shackle relocation kit from RC (http://www.roughcoun...xtras_1117.html)
