JEEPTALK.net: Air Bag/horn - JEEPTALK.net
Air Bag/horn
#1 User is offline   LazerManMike
  • Civilian Newbie
Posted 23 January 2012 - 11:09 AM
99 TJ air bag light is on and horn does not work so I pulled
the airbag\horn cover off in the process everything is unpluged
I dont know if I did it or if it was like that. There is a plug
with 2 wires which looks like it plugs into the center of the airbag
and 1 single wire which I think is for the horn. But after reading some post about
airbag kind of leary about pluging it back in. Is it safe to reconect these wires.
#2 User is offline   ChefJeep
Posted 23 January 2012 - 04:57 PM
i have helped a frend remove and replace an air bag heare is my advice i would place it in thew an open window keeping your hands twards the back and i would have the batteri disconected we had no propblem and i have very little micanical skills just be carefull and do not sit in the drivers seet while you are removing or installing this
An Evil genius bent on destroying grammatical standards...
SFJC Member
#3 User is offline   JBYDesign
  • Sergeant Major
Posted 24 January 2012 - 07:48 AM
so you are replacing the clockspring? disconnect the battery and you will be fine... touch the pos battery cable to the body(ground) NOT THE NEG POST! this will clear codes... and you are working with an inactive system... still handle with care... there are a couple write ups on jeepforum
'04 TJ 3" BL lift and 2.5" OME with 32" KM2s custom short cab frenched tail lights bedlinered int. shrockworks sliders custom H1 style intake, 20mm motor can consol, blacked out everything!
#4 User is offline   LazerManMike
  • Civilian Newbie
Posted 25 January 2012 - 12:52 PM
Thanks for the help
