this is actually on my other 4x4 a john deere tractor but an engines an engine right?
so think i have this figgured out, but i guess i'm looking for confirmation
so 2 winters now when its really cold out the tractor seems to run hot. all the rest of the year it's fine.i changed the t-stat, no difference. so now im wondering if it could be the fan clutch. ofcourse their supposed to be loose while the engine is cold. and as the engine warms up the clutch engages pulling more air thru the radiator right?
except when its this cold out maybe the clutch cant warm up soo its not pulling in air?? so my question is, it seems the clutch is doing what its supposed to, soo changing it wouldn't help, right?. what about covering both sides up between the radiatior and engine trapping more heat in there? or if anyone has any other idea's i'd really appreciate it.
thanks
engine running hot sometimes
Posted 21 January 2012 - 06:15 PM
Posted 23 January 2012 - 08:47 AM
Does it run hot, then cool off? If so check the bypass hose.
It could be the fan clutch, depending on how the air is getting to the clutch. Does it have open engine side panels?
Is the fan shroud in place?
Posted 23 January 2012 - 09:49 AM
i dont know if it has a bypass hose i'll check.
yes the sides are open and the fan shroud is only a couple of inchs deep. thats why i was thinking of covering the sides up. trap more heat in around the clutch and then the compartment could still vent out the bottom
Posted 23 January 2012 - 09:53 AM
Shroud should cover half the fan. If you can, put some vents in the panels that facce towards the back of teh tractor, it will help guide the air flow thru the rad over the fan clutch.
