installing Rampage side bars Help installing Rampage side bars on 87yj
Posted 12 January 2012 - 03:38 PM
Hey guys I just got my side bars and I know I am supposed to mount em on the frame mount however the instuctions is very blaaaahhh when I un screw the bolt un the body mount ity come out yes with a round peice of rubber this much I know now when i mount the bars I have to bolt it with the same screw however the round rubber thing is in the was and will not fit inside of the side bar mount or could i be doing something wron help!!!
Posted 13 January 2012 - 07:39 AM
Does the body mount bushing go on the other side of the sidebar.
Posted 13 January 2012 - 11:03 AM
this is the side bar installers pdf
http://www.quadratec...ation/54690.pdf
Posted 16 January 2012 - 09:37 AM
Froom the directions:
It sounds to me that the bar mount goes between the bolt and the bushing.
1 Remove the 2 existing body mount bolts from frame mounting locations located at front and rear of the Vehicle. Please note: Do not remove the rubber bushing from the retainer on the vehicle, the bracket mounts to the bushing with the factory bolts.
Posted 17 January 2012 - 12:56 PM
yeah it is but now heres the problem i go the unscrew it and the top brushing mount moves too what a mission
Posted 18 January 2012 - 07:50 AM
Welcome to world of Jeeps. The captured nut has probably broken loose. I don't know much about the YJ frames, but there may be a hole in it that you can get a wrench into to hold the captured nut to remove teh bolt.
Posted 19 January 2012 - 10:03 PM
I got a big a### wrench to clamp on it and hold it in place while i unscrew lol
Posted 21 January 2012 - 10:50 PM
Hot damn I had to drill a hole in to the chassis to get to the nut that had no tread in order to push out the screw lol but now i also have 2 bad brushing mounts so now i can't put the bars on till i get new or used bruising mounts andy leads
