Need a manual tranny in search for a manual tranny
Posted 14 December 2011 - 01:40 PM
Posted 14 December 2011 - 02:39 PM
Which seal is the one leaking? Is it the rear main seal? If so on Wranglers and CJ's they are replaceable without dropping the tranny. I did it on my TJ
Posted 14 December 2011 - 08:50 PM
Posted 17 December 2011 - 04:26 PM
Posted 17 December 2011 - 06:58 PM
J20 GONE TO NEW HAPPY OWNER,
BUILT'NOT BOUGHT..can ya really say it?
93-95 YJ Craigslist special...almost on the road...
Posted 29 December 2011 - 06:09 PM
awesome let me know brother I need to fix this baby I would appreciate it royaly lol
Posted 30 December 2011 - 01:28 AM
If the tranny pops out of gear in 2nd, 4th, or reverse (common problem with a lift) then the opening in the floor where the shifter hole is, has to be trimmed out about 1/4". But it sounds like you need new gears more than anything else.
Posted 03 January 2012 - 01:01 PM
help me out brother this is driving me nuts LOL
Posted 03 January 2012 - 03:28 PM
Posted 04 January 2012 - 11:07 AM
Wardie, on 03 January 2012 - 03:28 PM, said:
Posted 04 January 2012 - 04:36 PM
Posted 04 January 2012 - 05:40 PM
so let me ask you brother adding the shifter extender isnt hard and will it help if i put 410 gears in the dana?
quote name='Wardie' timestamp='1325712982' post='165740']
I won't rebuild the carb there is good mechanic near me though.
[/quote]
Posted 04 January 2012 - 05:54 PM
Posted 25 January 2012 - 06:12 PM
Wardie, on 04 January 2012 - 05:54 PM, said:
well I took myjeep to billys card and he checked it out turns out all i needed to do was connect the 12 volt power supply to it so my choke could open and close however I had an accumilation of oil in the carb turns out i have a blowby problem could be one of the seals for the pistons uuggghhh I also came accross and got em 1991 yj front and back axels with 410 gears in em hopefully that will fix the 5th gear problem if not i will have to go with a tranny swap whats your take on this guys
