so while on the internet i stumbled across the brute conversion but only for the tj i have a yj is it possible to make this work?
The Brute
Posted 15 December 2011 - 07:58 AM
While I have no experience with this conversion, you might just want to call AEV and ask, I'm sure they have a few tricks up their sleeve.
If you do find out please come back and let us know on your findings.
I really like the way this conversion looks.
Posted 16 December 2011 - 12:27 AM
im thinking that it wouldn't be that bad to build yourself from scratch. maybe a military trailer. and marry it up to the frame. it would allready have leaf spring mounts, then to move your axle back. and extend your driveshaft.
makes me think it might work on a cherokee too.
Posted 17 December 2011 - 03:46 PM
It wouldn't entirely work. The kit is a hi line in the front which you could do on your own. The rear section you could make work with a few mods. There is a 15" frame extension which in turn uses the tj frame to mount the rear tub. So chances are you would need a rear section from a tj which you could find for a couple hundred bucks.
Most people aren't brave, they are just too stupid to realize what they are doing.
2006 Jeep Wrangler Unlimited Rubicon 4.0 with a 6 speed hand shaker: 4" Skyjacker lift, Super Lift bent Control Arms, High Rock front and rear bumpers, Rubicon Express Hand throttle ,Cragar 15" Soft 8's wrapped with 35" Dunlop Mud Rovers.
VP High Rollers Jeep Club
Posted 17 December 2011 - 03:52 PM
Or you could just get yourself an LJ like me and skip all the hard work.
Or you could also check out rubitrux.com they make a cab enclosure kit and bulkhead for the rear for around $1300. I've only seen them on TJ's as well but I'm sure there is something for you poor souls with YJ's
Posted 17 December 2011 - 09:07 PM
No they don't make gimmick conversions for the YJ.
RockOn
1993 Jeep Wrangler
Work in Progress... has some stuff, needs some stuff, have a bunch of stuff to put in/on
1993 Jeep Wrangler
