Looking to get a cage trying to spend around $600 looking for a shop or someone local with the ability to bend and weld tubing.
A short description of what I want is pretty basic
In the front Im looking for the two bars that go across the top through the middle, two down bars to go through to the floor/frame and a bar to across the top of the windshield as well as a bar to go across the bottom of the windshield. Just like the first picture Ill post
In the back Im looking for sort of the YJ style roll bar But I'm running a half hardtop and would need to put a whole hoop just like the 2nd picture im posting
Anyone have any idea what this would cost, where I could get it done, etc?
Anyone have a cage built locally?
Posted 27 November 2011 - 10:31 AM
'06 TJ fixed.
2.5" OME Lift
Rubicon Express (pre 4wp) Track Bar in the front
OME Track Bar bracket in the rear
JKs Quick Disconnects
3"BL waiting to come off for my 1.25"BL
33x12.50R15 Mickey Thompson Baja Radial ATZ's
15x8 Cragar Soft 8's
Trail Gear front and rear bumpers.
Red LED interior lights.
2.5" OME Lift
Posted 28 November 2011 - 07:30 AM
sounds pretty expensive. might be a good time to look at your own welding rig and tube bender. you would be amazed at how much you use a welder once you have 1 or 2.
Posted 28 November 2011 - 07:36 AM
I've never even touched a welder, let a lone watch something be welded in person lol. A cage is something I wouldn't trust my lack of skills to. Probably the only thing I want "professionally" done. My budget is pretty flexible right now so I'm going to have to take it and get some quotes.
'06 TJ fixed.
2.5" OME Lift
2.5" OME Lift
Posted 28 November 2011 - 08:22 AM
There are kits that bring all the parts you need for a show cage. The reason it is called a show cage for for legalities. Once you get the tie in's to the frame, it will hold up the whole vehicle. Then all you need is a good welder to put it in. You can do a lot of the prep work, removing interior parts, cuttiong any holes needed, etc., and reduce the cost.
Posted 28 November 2011 - 11:10 AM
I know they sell the top picture I posted as a "show cage" in pieces. Hmmm might have to look into welding classes now.
'06 TJ fixed.
2.5" OME Lift
2.5" OME Lift
