Screaming 4 Banger Faster 2.5L TJs
Posted 20 November 2011 - 01:22 AM
Posted 21 November 2011 - 06:24 PM
38.5/14.5 tsl sx
Ballistic fab beadlocks
cobra 19 cb
superwinch 9500lb winch
8 inch fabtech rock crawler kit
3 inch body lift
and more...
Posted 22 November 2011 - 03:33 AM
RockTime, on 21 November 2011 - 06:24 PM, said:
Yes on my wish list as far as a E-fan goes, on the injectors been debating which ones to get. I also been looking at some 4 hole spray pattern ones. Then theres the ones at 505 performance. O yeah as far as e-fans goes I dont know with to go with a expensive flex a lite or like a tauras fan. At the same time I am concern about reliability.
Posted 22 November 2011 - 08:49 PM
the ford ones are a 4 hole and as far a fan i went with the one out of a camaro it fits perfect with 2 cuts
38.5/14.5 tsl sx
cobra 19 cb
3 inch body lift
and more...
Posted 23 November 2011 - 02:08 AM
Let me ask what size engine you have?
Posted 23 November 2011 - 10:43 PM
38.5/14.5 tsl sx
cobra 19 cb
3 inch body lift
and more...
Posted 24 November 2011 - 01:44 AM
RockTime, on 23 November 2011 - 10:43 PM, said:
Well Ok then good for you now we taliking. Ok what kind of injectors are they exactly? what year model did they come out of? Do you know the specs on them. O yes what year did your fan come from? How do you have the E-fan hooked up. Do you have a thermo swicth and relay or do you run it directly to a off on swicth or what. I know lots of questions.
Posted 25 November 2011 - 04:26 PM
38.5/14.5 tsl sx
cobra 19 cb
3 inch body lift
and more...
Posted 26 November 2011 - 12:06 AM
RockTime, on 25 November 2011 - 04:26 PM, said:
So she works pretty good with the electric fan, thats good. Yeah my rig runs so nice right now all the way around from crawling to wide open throttle Its hard to imagine it beening any faster. I am refering to the electric fan. My factory belt driven fan is lighter than stock because I got brave once awhile back and started triming the blades down little by little. Yeah I was worried making sure I would not reach the point of no return. Along with trimming the blades down I also bent the outer inside corners of each blade to reduce just a little drag as it spins. Well to my surprise it worked. My engine felt like it was spooling up a little quicker. Reaching higher RPMs faster of the line. Another plus to my surprise was she was even cooling better than before. The question is how much wieght was taking off of it. I dont know. I dont think it was that much, but it is a tad lghter. I believe the positive results came more from the bent angle of the blades. O yeah each blade also has a half inch hole drilled into it towards the end of each one. I know sounds a bit getto but she is working well. I did that mod about a year ago. I have had thoughts to mess with it a bit more, but maybe I should just leave well enough alone, thats spooky. But for now as far as a electric fan it will have to stay on my wish list for awhile. These days extra funds are hard to come by. Happy Wheeling my fellow jeeper. O yeah hope you had a good thanks giving.
