GSP Power Spacers outperforms the competition. This is more than just a ordinary spacer, it delivers the performance gains others fail to do. For 2.5L, 4.0s and 3.8L. Its patented designed air blades increase your intake air velocity through out the whole RPM range from crawling to wide open throttle with no air flow restrictions. No its not one of those thinga magigies that goes in your intake tube, this is a throttle body spacer like no other. It presurizes your incoming air right where it counts, yes just under that throttle plate. Enhanced HP, Torque, and 2 to 3 MPG increase. No we do not like to claim unbelievable HP gains like others do. Dyno shows 4 HP gain on a stock 4.0L and more can be gained with other modifications. But I tell you what you will feel the difference in seat off the pants dyno. We do suggest for best results to use in conjuction with a K&N filter. So if your running cold air intakes, bigger TB, or you 2.5L who use larger bore throttle bodys, why not utilize all that incoming air. Yes more air intake is good but to much you can lose your air charge costing you lost in power and torque. Slap one on and feel the difference. Check out www.gsppowerspacers.com or drop us a line at www.gsppowerspacers@aol.com
