New 4.2 Type Engine what 4.2 engine do i need
Posted 03 November 2011 - 09:45 PM
the casting number says it was made 10-25-83 so im guessing it was sold in a 1984 jeep.
Well the motor has too much oil blow by, low compression, leaking head gasket and a crack in the exhaust manifold
TIME FOr NEW ENGINE
I do not want to put in a v8 i like the 4.2
So question is
What motor do i need to buy????
I see 4.2 motors all different years all over ebay for 1,000 to 1999 shipped depending on what year.
I have the ax15 tranny.
I want to make sure that when i get the new engine that my cooling system, intake manifold, exhaust and tranny all bolt in with no headaches.
this will be my first engine swap and I'm pretty sure me and a friend can do it in an afternoon.
one more question. i know the motor mounts from a 1984 4.2 to a 90 4.2 have to be different correct? why cause i have 1990 motor mounts and have like a 2 inch gap of open space from the mount bracket and the actuall rubber motor mount.
any advice will be great thank you
I'm also considering buying the master engine rebuild kit and taking it to a shop to have them do it. So if anyones knows a good jeep shop that would rebuild my motor in the broward county area let me know.
THANKS
Posted 04 November 2011 - 06:34 AM
Posted 06 November 2011 - 12:50 AM
A good rebuild would be about 1200 bucks but you can cut that way down by doing a lot of the work your self. Question is, do you want the 258 w/good low-end torque, or a good v8 w/lots of power but able also to have low-end torque (cam). AMC-360 is a good swap and the T-176 would hold up better than the ax15, the TF-999 3spd is another good tranny but it is auto. The 360 does have some good low-end torque and if you go dual exhaust keep the pipe @ 2.25, this will help as well.
Posted 06 November 2011 - 10:28 AM
Posted 06 November 2011 - 12:20 PM
Posted 07 November 2011 - 08:50 PM
he told me to go with jasper motors....
well they have a great rep but with that rep comes a good price. they wanted to sell me the jeep 4.2 long block for
2460.99 and thats with my core and they stated if there is a crack or problem with my block they wont give me my core deposit back. hummmmmmmm seems kinda high i dont have that cash lying around....
i also started looking for a master rebuild kit but there are so many compaines out there selling them prices go from 399.99 to 790.00 ......... i did find out that most the kits on e-bay are enginetech and im kinda scared about those kits
there is another kit on ebay put together by a company called mabco or something like that i googeld them and they have a very bad rep
so further investigation i found this site jeepenginesales.com
they will sell me a long block shipped to my door for 1,469.99
can anyone tell me that the parts they use are good parts or not here is the list
Engines remanufactured by our remanufacturing line meet or exceed O.E.M. specifications.
- New Manley valves
- New Elgin valve springs and keepers
- New Badger pistons
- New Hastings molly rings
- New Dynagear timing gears and Durabond cam bearings
- New Dynagear timing gears and chain
- New Elgin lifters, push rods, rockers, balls and nuts
- New Dynagear oil pump
- New FelPro gaskets
- Cylinder heads are pressure checked
- Diamond honed valve guides
- Three angle cut valve seats
- All head surfaces are broached
- Blocks are bored with deck plates, cylinder walls are diamond honed
- Crankshafts are ground and polished for .002 clearance
- Camshafts are ground to O.E.M. specifications, hardened and polished
- Connecting rods are sized to .002 clearance
Back to top
Q: What is your Warranty policy?
A: See below a summary of our engine warranty.
Passenger car and light SUV longblocks are covered for 7 years or 70,000 miles. If failure of a long block should occur during the first twenty-four months and it is determined the failure is due to a defect in workmanship or parts installed by us, we will replace or repair the defective unit to the original buyer. During the balance of the warranty, we will replace the long block at one-half of the current retail price.
The Standard limit labor reimbursement covers labor at $40.00 per hour up to a maximum of $500.00. Premium warranty can be purchased at the time of sale.
I also got quoted from my friends at mustang specialties in pompano beach fl. they would do all the work to rebuild my motor for a labor charge of 1,000.... so if i could find a good master rebuild kit i might go that way...
any advice is great
Posted 13 November 2011 - 04:09 PM
Posted 14 November 2011 - 09:25 AM
Posted 24 January 2012 - 02:29 PM
Posted 04 June 2013 - 05:58 PM
If you look back in the archives about a 4.0ho engine rebuild, you should see all of my progress in step by step with pics..
And yes, to those who haven't seen me on here in quite a long time, IM STILL ALIVE.
Frank
Posted 06 June 2013 - 06:45 AM
GUTSY"S BUILD
Posted 06 June 2013 - 07:04 PM
Frank
Posted 07 June 2013 - 06:06 AM
Posted 11 June 2013 - 04:51 PM
JeepinIan, on 07 June 2013 - 06:06 AM, said:
Thanks Ian! Ive been busy doing the usual,,, work and fun.. I recently started riding my Harley again.. Anytime you want to go lemme know
Posted 12 June 2013 - 06:05 AM
