saw this on another form do u like to do a 4 or 5 tire rotation and what patern do you rotate in
tire rotation how do u like to rotati yoru tires
Posted 11 August 2011 - 10:14 AM
An Evil genius bent on destroying grammatical standards...
SFJC Member
SFJC Member
Posted 11 August 2011 - 01:27 PM
oppposite corners front to opposing back... take your pick and rotate the spare into the mix... typically one of the new fronts... but south of the equator the rotation should be clockwise!
'04 TJ 3" BL lift and 2.5" OME with 32" KM2s custom short cab frenched tail lights bedlinered int. shrockworks sliders custom H1 style intake, 20mm motor can consol, blacked out everything!
Posted 02 October 2011 - 12:11 PM
If you do not have directional treads you might try taking a reading of the tread height on each of your tires and moving the best tire to the location showing the worst tread wear. I rotate all 5 of mine in this manner. They all wear down at the same time by doing this, allowing me to change tires altogether when the time comes. I do mostly highway driving and according to my girlfriend drive too fast around curves. If you check the treads, this results in outside tread loss which reduces the cornering ability. To counter this, when it becomes noticeable I turn the tires around putting the best tread on the outside. Hope this helps.
Posted 02 October 2011 - 02:45 PM
Drive wheels directly to the front or rear. Idle wheels crossed to the front or rear. This way, eventually all tires will hit all the corners.
I ain't as good as I once was, but I'm as good once as I ever was.
http://www.youtube.c...h?v=TZBTyTWOZCM
1-20-2013...end of an error
Posted 03 October 2011 - 09:12 AM
I rotate the spare into the mix, My pattern is spare->LR, LR->LF, LF->RR, RR->RF, RF->spare
2010 JK Sport Unlimited
RuggedRidge XHD Bumper with stinger
Recon 10,500 lb Waterproof Winch
TeraFlex 2.5" Coil lift + Spacer Leveling Kit = More lift than I bargained for...
Smittybilt SRC Side Armor
KC SlimLite 130W on KC windshield brackets
35" Fierce Attitude M/T
Wish List
Snorkel
On Board Air
Windshield Lights
Front Fog Lights
Lockers
35" Mud Tires
Wish List
Snorkel
On Board Air
Front Fog Lights
Lockers
Posted 03 October 2011 - 09:50 AM
I rotate all 5 tires, about every 5,000 miles.
My pattern:
LR>LF LF>SPARE SPARE>RR RR>RF RF>LR
My pattern:
1982 CJ-7, 31" tires, 12,000 lb. Ramsey Winch.
SFJC, Jeep Club Advisor
