JEEPTALK.net: Fabrication Shop - JEEPTALK.net
Fabrication Shop
#1 User is offline   1BadCJ5
  • Sergeant FirstClass
Posted 10 August 2011 - 08:53 AM
To SFJC members,
If anybody needs any help on doing any custom mods on there Jeeps let me know. It sure helped when I built my 1973 CJ5. I'm located in the center of Ft. Laud. off Broward Blvd. & East of I95.
#2 User is offline   BS13855
Posted 31 August 2011 - 02:20 PM
Absolutely will need some of your help. Do you have a sand blaster
#3 User is offline   1BadCJ5
Posted 31 August 2011 - 02:34 PM
What do you want to sand blast?
#4 User is offline   BS13855
Posted 31 August 2011 - 07:35 PM
A Dana 30 axle
And do you do welding and pipe bending?
#5 User is offline   1BadCJ5
Posted 01 September 2011 - 09:43 AM
I found a guy in N. Lauderdale for the sandblasting. I'll look through my records to find you his name.
The welding is no problem. At this point I don't have a tube bender. When I did my full cage on my CJ5 I did it by doing pie cuts and welding the cut then grinding and sanding the weld. It took alot of time but came out SWEET.
If you have the time stop by my shop. I'm just west of downtown Ft. Laud.
Russ 954.290.1957
